Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Help creating motorR6-9 examples
From: Guilherme Jovanini Montagner <guilherme@setup.com.br>
To: "Ronald L. Sluiter" <sluiter@anl.gov>
Cc: tech-talk <tech-talk@aps.anl.gov>
Date: Tue, 12 Sep 2017 17:25:24 -0300 (BRT)
Hi.
Ok, here it is (attached)
I'll have to go now, but I'll come back.
Thanks!
+55 19 2517.8911
+55 19 99806.9117
----- Mensagem original -----
De: "Ronald L. Sluiter" <sluiter@anl.gov>
Para: "guilherme" <guilherme@setup.com.br>
Cc: "tech-talk" <tech-talk@aps.anl.gov>
Enviadas: Terça-feira, 12 de setembro de 2017 17:17:16
Assunto: Re: Help creating motorR6-9 examples
Could you run the following command at the top directory,
> make >& makedump.txt
and send me the file.
Ron
On 09/12/2017 03:13 PM, Guilherme Jovanini Montagner wrote:
> Hi again. Yes, I have run make from the top, and after, tried running it again from the child directory.
> +55 19 2517.8911
> +55 19 99806.9117
> Para: "guilherme" <guilherme@setup.com.br>, "tech-talk" <tech-talk@aps.anl.gov>
> Enviadas: Terça-feira, 12 de setembro de 2017 17:06:32
> If you did not run "make" from the top level "motorR6-9" directory, that could
> be why you are getting these errors. The EPICS motor module, like EPICS base and
> most other EPICS modules, assumes that "make" is run 1st from the top level
> directory. After running 'make' from the top level you can make custom changes
> and taylor the module to your specific needs, but you should run make from the
> top 1st.
> Ron
> On 09/12/2017 02:57 PM, Ronald L. Sluiter wrote:
>> Hello Guilherme,
>> I am guessing that the SoftMotorSrc directory did not get built. If you 'ls'
>> the SoftMotorSrc directory you should get this;
>>> % ls motorApp/SoftMotorSrc
>>> devSoftAux.cc  devSoft.cc  devSoft.h  devSoftMotor.dbd Makefile  O.Common
>>> O.linux-x86_64
>> and there should be a 'devSoftMotor.dbd' file installed in the top 'dbd'
>> directory.
>>> galadriel% ls dbd
>>> ACRMotorSupport.dbd  devDeltaTau.dbd        devMclennanMotor.dbd
>>> devNewport.dbd  devPIJena.dbd *devSoftMotor.dbd* MicronixSupport.dbd
>>> motorSupport.dbd         omsAsynSupport.dbd
>>> devAcsMotor.dbd      devFaulhaberMotor.dbd  devMicos.dbd devOms.dbd
>>> devPIMotor.dbd      devSPiiPlus.dbd motorRecord.dbd      NoAsyn.dbd
>>>        phytron.dbd
>>> devAerotech.dbd      devImsMotor.dbd        devMicroMo.dbd devOriel.dbd
>>> devSmarActMCSMotor.dbd  devThorLabs.dbd motorSim.dbd         NoAsynVx.dbd
>>>        PI_GCS2Support.dbd
>>> devAttocube.dbd      devKohzuMotor.dbd        devNewFocus.dbd
>>> devPC6K.dbd      devSmartMotorMotor.dbd  HytecMotorDriver.dbd
>>> motorSimSupport.dbd  NPointMotorSupport.dbd
>> What do you see in those two directories?
>> Ron
>> On 09/12/2017 02:25 PM, Guilherme Jovanini Montagner wrote:
>>> Hi!
>>> I'm involved in a Project in which EPICS is to be used, and am currently
>>> trying to create a working example using a PI piezo controller.
>>> I want some help doing this.
>>> I've uncommented the lines
>>> DIRS += motorExApp iocBoot
>>> motorExApp_DEPEND_DIRS = motorApp
>>> iocBoot_DEPEND_DIRS = motorExApp
>>> from the top makefile. I've also uncommented the line "MOTOR=$(TOP)" in
>>> configure/RELEASE file
>>> Also, on the file motorApp/Makefile, I've got the lines
>>> DIRS +=PIGCS2Src
>>> PIGCS2Src_DEPEND_DIRS = MotorSrc
>>> uncommented.
>>> The problem is, when I run make on top, I get the following message:
>>> [setup@localhost motorExApp]$ make
>>> make -C ./NoAsyn install
>>> make[1]: Entering directory
>>> `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn'
>>> make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
>>>      T_A=linux-x86_64 install
>>> make[2]: Entering directory
>>> `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn/O.linux-x86_64'
>>> Creating dbd file NoAsyn.dbd
>>> perl -CSD /home/setup/Downloads/base-3.16.1/bin/linux-x86_64/dbdExpand.pl -I.
>>> -I.. -I../O.Common -I../../../dbd
>>> -I/home/setup/Downloads/support/asyn4-31/dbd
>>> -I/home/setup/Downloads/base-3.16.1/dbd -o NoAsyn.dbd base.dbd
>>> motorRecord.dbd devSoftMotor.dbd Misc.dbd
>>> dbdExpand.pl: Can't find file 'devSoftMotor.dbd'
>>>    while reading 'devSoftMotor.dbd' to create 'NoAsyn.dbd'
>>>    Your Makefile may need this dependency rule:
>>>      $(COMMON_DIR)/NoAsyn.dbd: $(COMMON_DIR)/devSoftMotor.dbd
>>> dbdExpand.pl: Exiting due to errors
>>> make[2]: *** [../O.Common/NoAsyn.dbd] Error 255
>>> make[2]: Leaving directory
>>> make[1]: *** [install.linux-x86_64] Error 2
>>> make[1]: Leaving directory
>>> make: *** [NoAsyn.install] Error 2
>>> Then, I proceeded to add the mentioned line on motorExApp/NoAsyn/Makefile:
>>>   ADD MACRO DEFINITIONS AFTER THIS LINE
>>> PROD_IOC_DEFAULT = NoAsyn
>>> PROD_IOC_vxWorks = NoAsynVx
>>> COMMONDBDS  = base.dbd
>>> COMMONDBDS += motorRecord.dbd
>>> COMMONDBDS += devSoftMotor.dbd
>>> #!COMMONDBDS += devMXmotor.dbd
>>> but when I run make again, after doing that, I get the following error:
>>> Creating dbd file devSoftMotor.dbd
>>> -I/home/setup/Downloads/base-3.16.1/dbd -o devSoftMotor.dbd
>>> dbdExpand.pl: No input files for devSoftMotor.dbd
>>> make[2]: *** [../O.Common/devSoftMotor.dbd] Error 255
>>> I don't know where is this devSoftMotor.dbd being called, and why it doesn't
>>> have input arguments.
>>> Could you help me, please?
>>> Thanks,
>>> Guilherme
>>> *Guilherme Jovanini Montagner*
>>> +55 19 2517.8911
>>> +55 19 99806.9117
make -C ./configure install
make[1]: Entering directory `/home/setup/Downloads/support/motor/motorR6-9/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
make[2]: Entering directory `/home/setup/Downloads/support/motor/motorR6-9/configure/O.linux-x86_64'
perl -CSD /home/setup/Downloads/base-3.16.1/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory `/home/setup/Downloads/support/motor/motorR6-9/configure/O.linux-x86_64'
make[1]: Leaving directory `/home/setup/Downloads/support/motor/motorR6-9/configure'
make -C ./motorApp install
make[1]: Entering directory `/home/setup/Downloads/support/motor/motorR6-9/motorApp'
make -C ./MotorSrc install
make[2]: Entering directory `/home/setup/Downloads/support/motor/motorR6-9/motorApp/MotorSrc'
make[3]: Entering directory `/home/setup/Downloads/support/motor/motorR6-9/motorApp/MotorSrc/O.linux-x86_64'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory `/home/setup/Downloads/support/motor/motorR6-9/motorApp/MotorSrc/O.linux-x86_64'
make[2]: Leaving directory `/home/setup/Downloads/support/motor/motorR6-9/motorApp/MotorSrc'
make -C ./PIGCS2Src install
make[2]: Entering directory `/home/setup/Downloads/support/motor/motorR6-9/motorApp/PIGCS2Src'
make[3]: Entering directory `/home/setup/Downloads/support/motor/motorR6-9/motorApp/PIGCS2Src/O.linux-x86_64'
make[3]: Leaving directory `/home/setup/Downloads/support/motor/motorR6-9/motorApp/PIGCS2Src/O.linux-x86_64'
make[2]: Leaving directory `/home/setup/Downloads/support/motor/motorR6-9/motorApp/PIGCS2Src'
make -C ./Db install
make[2]: Entering directory `/home/setup/Downloads/support/motor/motorR6-9/motorApp/Db'
make[3]: Entering directory `/home/setup/Downloads/support/motor/motorR6-9/motorApp/Db/O.linux-x86_64'
make[3]: Leaving directory `/home/setup/Downloads/support/motor/motorR6-9/motorApp/Db/O.linux-x86_64'
make[2]: Leaving directory `/home/setup/Downloads/support/motor/motorR6-9/motorApp/Db'
make[1]: Leaving directory `/home/setup/Downloads/support/motor/motorR6-9/motorApp'
make -C ./motorExApp install
make[1]: Entering directory `/home/setup/Downloads/support/motor/motorR6-9/motorExApp'
make[2]: Entering directory `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn'
make[3]: Entering directory `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn/O.linux-x86_64'
perl -CSD /home/setup/Downloads/base-3.16.1/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/home/setup/Downloads/support/asyn4-31/dbd -I/home/setup/Downloads/base-3.16.1/dbd -I../../../dbd -o devSoftMotor.dbd
make[3]: *** [../O.Common/devSoftMotor.dbd] Error 255
make[3]: Leaving directory `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn'
make[1]: *** [NoAsyn.install] Error 2
make[1]: Leaving directory `/home/setup/Downloads/support/motor/motorR6-9/motorExApp'
make: *** [motorExApp.install] Error 2
Help creating motorR6-9 examples Guilherme Jovanini Montagner
Re: Help creating motorR6-9 examples Ronald L. Sluiter
Re: Help creating motorR6-9 examples Guilherme Jovanini Montagner
Prev: Re: Help creating motorR6-9 examples Pete Jemian
Next: Fwd: Re: Help creating motorR6-9 examples Ronald L. Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: Re: Help creating motorR6-9 examples Guilherme Jovanini Montagner
ANJ, 12 Sep 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
