Hi Iain,
On 09/12/2017 08:39 AM, Iain Marcuson wrote:
> That solved the problem. The Text Input widgets update with their new values
> The IOC holds the values e.g. "start", "stepsize" and "end" parameters
> as separate PVs. A fourth PV triggers Stream Device to write those three
> PVs over TCP/IP to the "backend hardware" in one transaction.
The fact that your widgets weren't updating automatically suggests to me
that those other PVs might not have been configured correctly, because
Text Input boxes should update automatically when they get a monitor
event from the IOC. The fact that yours aren't implies that somehow
their values are being changed (presumably by the hardware) without
triggering record processing, which would trigger a CA update event and
thus update the GUI automatically. Your approach might work fine with
CS-Studio, but a different GUI tool might not have the same ability, so
I don't recommend that you accept this as the right solution.
Is this a situation where those PVs can be updated from either the GUI
or the back-end hardware? There are techniques people have developed to
handle this correctly if it is.
- Andrew
- RE: Automatic refresh of OPI Iain Marcuson
- Automatic refresh of OPI Iain Marcuson
- Re: Automatic refresh of OPI Kasemir, Kay
<2017>
<2017>
