1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: mca R7-7 now available
Date: Fri, 8 Sep 2017 19:07:00 +0000
Folks,
mca R7-7 is now available.
This is from the release notes:
- Added support for the Amptek DP5 based MCAs and detectors. This is documented here.
- Moved the repository from Subversion at the APS to github.com/epics-modules/mca
- mcaRecord.dbd: Changed the data type of the preset count (PCT) field from DBF_LONG to DBF_DOUBLE.
  The value can reasonably be larger than an epicsInt32 will hold. devMcaAsyn.c and most drivers were already (incorrectly) treating the field as a double.
- Bruker QM100: Fixed the datatype of the mcaPresetCounts parameter.
- SIS3801 and SIS3820:
    - Fixed problems when the number of signals being used (maxSignals) was 32.
      In this case the left shift operator was shifting by 32-bits which is undefined, and could disable all channels rather than enabling all channels on some architectures.
    - Changed the VME interrupt release method from the default RORA to ROAK for CPU boards that use the Tsi148 and rely on software initiated IACK cycles.
- Added .NUSE to simple_mca_settings.req.
- Minor change to allow building on mingw.
- Removed building mcaCanberra on cygwin-x86. WinPCAP libraries do not work with latest Cygwin version.
The home page is here:
http://cars.uchicago.edu/software/epics/mca.html
The release notes are here:
http://cars.uchicago.edu/software/epics/mcaReleaseNotes.html
The source code repository is here:
Let me know of any problems or suggestions.
Prev: Re: Nightly builds Amien Crombie
Next: Automatic refresh of OPI Iain Marcuson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
