De: Lang, Keenan C. <[email protected]> Enviado: quarta-feira, 6 de setembro de 2017 14:48 Para: Paduan Donadio, Marcio; [email protected] Assunto: Re: StreamDevice hexa checksum in lowercase characters
If this is running on an operating system that has the PCRE library, you can enable the streams regex converter
Setup 1. Prerequisites. StreamDevice requires either EPICS base R3.14.6 or higher or EPICS base R3.13.7 or higher. How to use StreamDevice on EPICS R3.13 is described ...
This will allow you to find and replace substrings before the string gets outputted. Unfortunately, the result looks a bit ugly:
out STX "590000%01<sum>%#/A/a/%#/B/b/%#/C/c/%#/D/d/%#/E/e/%#/F/f/";
