1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Base 3.15 and record initialization
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Sat, 2 Sep 2017 10:39:26 +0200
Hi Michael,
> Notice the "MS" in the calc record's INPA.  We don't yet know why the original developer did this,
> and it seems that it would just cause the record to get stuck in an alarm state if any input went into an alarm state.
if you want to keep that behaviour, then you should not change the self reference link to "NMS".
Instead you should change to
record(calc, "TEST123:CalcTest") {
  field(INPA, "TEST123:CalcTest NPP MS")
  field(INPB, "TEST123:AoTest NPP MS")
  field(CALC, "B<100?(A+1):A")
  field(FLNK, "TEST123:AiTest")
  field(SEVR, "NO_ALARM")
  field(UDF, "0")
But it might even be that your problem has nothing to do with the upgrade to 3.15.
If the developer wanted to latch all alarms of the inputs, then he probably provided a mechanism to reset the alarm.
Once you do that, you don't want to have it reset just because you've rebooted.
Therefore you put the SEVR and UDF fields of the calc record into autoSR / bumpless reboot configuration.
If those configuration was not there for a single reboot (that might happen when you upgrade),
then you'll end up with INVALID / UDF alarms in the calc record.
If that was the case then do not change the DB, just set once SEVR=NO_ALARM manually and it'll work as before.
I hope that helped a little?
Cheers
Andreas
Prev: Re: Base 3.15 and record initialization Bruce Hill
Next: Re: Base 3.15 and record initialization Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: Base 3.15 and record initialization Johnson, Andrew N.
Next: data refresh and add pv 梁雅翔
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
