Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Archiver: Problems with disconnected PVs
From: "Shankar, Murali" <mshankar@slac.stanford.edu>
To: Gabriel de Souza Fedel <gabriel.fedel@lnls.br>, "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Fri, 1 Sep 2017 18:10:30 +0000
>> is there another location
Depends on your setup of course but I see something like this in my arch.log right at the beginning.
<context class="com.cosylab.epics.caj.CAJContext">
  <preemptive_callback>true</preemptive_callback>
  <addr_list>gateway:5076 gateway:5077 gateway:5078 other-gateway:5064</addr_list>
  <auto_addr_list>false</auto_addr_list>
  <connection_timeout>30.0</connection_timeout>
  <beacon_period>15.0</beacon_period>
  <repeater_port>5069</repeater_port>
  <server_port>5076</server_port>
  <max_array_bytes>80000000</max_array_bytes>
  <event_dispatcher class="org.epics.archiverappliance.engine.epics.JCAEventDispatcherBasedOnPVName"/>
</context>
>> pause/resume I tried
Pausing/resuming tears down and recreates the CAJ channel for the PV so if you are unable to connect even after this you probably have some misconfiguration; that is, you can rule out most transient errors.
>> IOC's log on ioc machine right
Yes; sometimes there could be stuck tasks on the IOC side; you can check for that.
Your PV Details page for this PV could have information there that could help. You can get to this using something like so - http://localhost:17665/mgmt/bpl/getPVDetails?pv=Your_PV
Finally, would you be in a position to attempt a restart?
Murali
From: Gabriel de Souza Fedel <gabriel.fedel@lnls.br>
Sent: Friday, September 1, 2017 10:52 AM
To: Shankar, Murali; tech-talk@aps.anl.gov
Cc: (mdavidsaver@gmail.com)
Em 01-09-2017 13:39, Shankar, Murali escreveu:
>>> This seems like it might be a CA client configuration issue
> This is the most likely case. The engine prints out it's CAJ
> configuration on startup and you should be able to see this in your logs.
I didn't find it. I find engine/logs/catalina.err, is there another
location?
> You can try a couple of things. You can pause/resume the PV's in
> question and see if they reconnect back. You can also look in the IOC's
> logs and see if there is anything interesting going there.
pause/resume I tried. IOC's log on ioc machine right? apparently there
is no errors (on epics console).
> Regards,
Regards and thank you for the answer
> Murali
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
gabriel.fedel@lnls.br | +55 (19) 3512 1226
www.lnls.cnpem.br
Re: Archiver: Problems with disconnected PVs Gabriel de Souza Fedel
Re: Archiver: Problems with disconnected PVs Shankar, Murali
Prev: Re: Archiver: Problems with disconnected PVs Gabriel de Souza Fedel
Next: Re: Archiver: Problems with disconnected PVs Gabriel de Souza Fedel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
ANJ, 01 Sep 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
