1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: FTP server on Linux(Ubuntu)
To: Amit Chauhan <[email protected]>
Date: Fri, 1 Sep 2017 17:23:04 +0200
Dear Amit,
I am using the pure-ftpd on ubuntu servers.
pure-ftpd - simple File Transfer Protocol server
Works to boot RTEMS-targets. Works also with our vxWorks systems.
Best regards,
Heinz
> On 01 Sep 2017, at 14:12, Amit Chauhan <[email protected]> wrote:
> Hello,
> This is regarding use of FTP server on a Linux (Ubuntu) PC.
> I am trying to use an Ubuntu 14.04 PC as an FTP server by using the 'vsftpd' application.
> The client is a VME based CPU running vxWorks that needs to download kernel image over FTP.
> This client is getting served when I am using a Windows based FTP server.
> But somehow the FTP connection is not getting established between the VME client and Ubuntu based server.
> The error messages I get on client side are like :
> FTP Transfer Failed
> Error Code = 0x3d  (ECONNREFUSED)
> I googled about the problem and tried a few suggestion of making changes in the vsftpd.conf file , but to no avail.
> Also I do not see any entry in the log file on the server (/var/log/vsftpd.log)
> The FTP service seems to be running on the PC as I get a task ID. Also when I type the command 'ftp <self IP-address>' in a terminal , I get the 'ftp>' prompt.
> Has anybody successfully used the vsftpd on Ubuntu (or Linux in general) PC to server an external VME like client ?
> Thanks,
> Amit
Attachment: smime.p7s
Description: S/MIME cryptographic signature
FTP server on Linux(Ubuntu) Amit Chauhan
Prev: RE: FTP server on Linux(Ubuntu) Mark Rivers
Next: Re: Another EPICS site, CSNS now producing neutrons Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: Re: FTP server on Linux(Ubuntu) Jani Hakala
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
