1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: C++ multi threaded application.
To: [email protected]
Cc: Lucio Zambon <[email protected]>
Date: Fri, 1 Sep 2017 16:59:04 +0200
Hello all Epics world, I am Giacomo Strangolino from the Elettra
Synchrotron Radiation Facility in Trieste, Italy.
I am new to Epics, and I am writing a C++ multi threaded library in
order to write GUIs in Qt and I have the following constraints:
- I want to monitor a pv in a separate thread;
- when a new value is available, I want a callback to be invoked (always
in the same background thread). There I extract data and forward it to
the main (GUI) thread.
- the background thread implements a wait condition so that it sleeps
until a new event arrives (for example, exit event or new variable to be
monitored is added)
I set things up like this in the init() method of a class I called
"CuMonitorActivity".
I used a pv structure as in camonitor C example:
void CuMonitorActivity::init()
    int caTimeout = DEFAULT_TIMEOUT;
    int reqElems = 1;
    int nPvs = 1;
    pv* pvs;                    /* Array of PV structures */
    int result = ca_context_create(ca_enable_preemptive_callback);
    if (result != ECA_NORMAL) {
    else
        /* Allocate PV structure array */
        pvs = (pv *) calloc (nPvs, sizeof(pv));
        if (!pvs)
        else {
            /* Connect channels */
            memset(pvs[0].name, 0, 256);
            strncpy(pvs[0].name, "giacomo:ai1", 255);
            pvs[0].monitor_activity = this; /* store a reference to this
object to be used in the callback */
            /* Create CA connections */
            int returncode = create_pvs(pvs, nPvs, connection_handler_cb);
            if ( returncode ) {
    publishResult(tk);
NOTE: I enabled preemptive_callback so that I get
connection_handler_cb() called regularly when a new event arrives
 From within connection_handler_cb I extract the current
CuMonitorActivity instance (stored in pv's monitor_activity field) and I
invoke the object's extraction method. Data is posted in the main thread.
NOTE: I notice that connection_handler_cb is invoked from ANOTHER
thread, not my main thread, not my secondary thread. This should be as
expected I guess for things to work and given the ca_
enable_preemptive_callback option.
* when I post an "exitEvent" on my secondary thread from the main one
(e.g. the GUI is closed),  "ca_context_destroy();" is invoked in my
secondary thread (not the Epics thread that calls connection_handler_cb
during monitoring - is this OK? )
* Is there a way to ADD more PVs to monitor WHILE others are being
monitored (for example, is it legit to call create_pvs() again ) ?
* Are there any observations/corrections to my approach and to my
statements above?
Thanks for Your attention.
Giacomo Strangolino, Italy.
Re: C++ multi threaded application. Andrew Johnson
Prev: Re: Another EPICS site, CSNS now producing neutrons Dave Gurd
Next: Re: FTP server on Linux(Ubuntu) keith.thorne
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: Archiver: Problems with disconnected PVs Gabriel de Souza Fedel
Next: Re: C++ multi threaded application. Andrew Johnson
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
