1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Running CSS-4.5 from Eclipse Neon
To: "Kasemir, Kay" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Wed, 30 Aug 2017 18:28:41 +0200
Hi Kay
I'm using your help in <<https://github.com/kasemir/org.csstudio.display.builder>> as a guideline in installing CSS inside Eclipse.
Yes, I'm trying to get CSS inside Eclipse (have installed Neon 4.6)
Then added
Installed CSS Core ok but struggling to get the 'others' working...It goes into a install loop about 60% of the downloads and then get stuck.
In Eclipse-Neon I see the CSS in my preferences with all the settings one can use..
Regards
Amien
On 29/08/2017 19:09, Kasemir, Kay wrote:
Hi:
I'm giving a small intro into my new CSS app to other CSS users this Friday. All of them are still using BOY/Opi with mostly Jython scripting.
As my knowledge on Java is not great, I need to some advise on the following (if you have time):
The 'Builder' can convert most OPI files but the underlying scripts must be changed to the new 'Display' java classes.
Right.
As much as possible and coding time allows, it reads existing displays, at least to the extend that I absolutely need this for operation of SNS beam lines where we have existing *.opi files.
What doesn't convert:
Scripts: They were always reserved for special cases, to do things that were impossible with EDM, MEDM, ...
If you have to ask how to do a script, you probably shouldn't use them.
If you still wanted to use them, you can now rewrite them.
Is there indication that other CSS users are also moving to the Builder ?
You'd have to ask them.
ESS has been contributing to the display builder, they intend to use it.
FRIB is interested.
Those that have many *.opi files will certainly need some time to update, that's OK.
But starting a new project with BOY now, and continuing to add code to BOY at this time is a very bad idea:
The BOY code entangles model, runtime and display. It's 99% on the UI thread and tightly depends on SWT, which in turn is dead.
Any way to add a genuine debugger in the newer CSS ? (or is this already possible?)
Not sure what you mean.
You can attach jvisualvm to the running instance to monitor CPU, memory, ..
You can start CSS from within Eclipse in debug mode and then single-step through everything.
Kay
Re: Running CSS-4.5 from Eclipse Neon Kasemir, Kay
CSS-4.5 : Display-Builder : getting widget's PV value Amien Crombie
Re: CSS-4.5 : Display-Builder : getting widget's PV value Kasemir, Kay
Re: CSS-4.5 : Display-Builder : getting widget's PV value Amien Crombie
Prev: EPICS Workshop at ICALEPCS in Barcelona Timo Korhonen
Next: Re: Running CSS-4.5 from Eclipse Neon Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: CSS-4.5 : Display-Builder : getting widget's PV value Kasemir, Kay
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
