1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Problems building seq 2.2.4 on Linux
To: Mark Rivers <[email protected]>, Tech-talk <[email protected]>
Date: Fri, 25 Aug 2017 14:32:09 -0400
Hi Mark,
   I had just figured out that my configuration files do not properly define INSTALL_HOST_BIN by forcing the  %.lem rule.
Anyway, when I fixed the definition of INSTALL_HOST_BIN it builds with only the following warnings:
devl06 [170]: gmake -sj clean
devl06 [171]: gmake -sj
../Makefile:51: PATH_FILTER is deprecated; used for ../../../bin/rhel-6-ia32/lemon
../Makefile:52: PATH_FILTER is deprecated; used for ../../../bin/rhel-6-ia32/lemon
2 parsing conflicts.
../Makefile:63: PATH_FILTER is deprecated; used for ../../../bin/rhel-6-ia32/lemon
devl06 [172]:
Thanks for you help!
Sue
On 08/25/2017 01:55 PM, Mark Rivers wrote:
Hi Sue,
I just installed a fresh copy of seq-2.2.4 and built it on my RHEL6 system.  The only file I changed was configure/RELEASE to properly point to my base.
I am running the same RHEL6 OS, same gcc, same version of make, and same version of perl as you are.
This is the output I get when I build the src/snc directory, which is what is failing for you:
make[2]: Entering directory `/corvette/home/epics/devel/seq-2.2.4/src/snc'
perl -CSD /corvette/usr/local/epics/base-3.15.5/bin/linux-x86-rhel6/makeMakefile.pl O.linux-x86-rhel6 ../../..
mkdir O.Common
make -C O.linux-x86-rhel6 -f ../Makefile TOP=../../.. \
            T_A=linux-x86-rhel6 install
make[3]: Entering directory `/corvette/home/epics/devel/seq-2.2.4/src/snc/O.linux-x86-rhel6'
/corvette/home/epics/devel/seq-2.2.4/bin/linux-x86-rhel6/lemon o=. ../snl.lem
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-3.15.5/include/compiler/gcc -I/corvette/usr/local/epics/base-3.15.5/include/os/Linux -I/corvette/usr/local/epics/base-3.15.5/include        -MM -MF snl.d  snl.c
re2c -s -b -o lexer.c ../snl.re
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-3.15.5/include/compiler/gcc -I/corvette/usr/local/epics/base-3.15.5/include/os/Linux -I/corvette/usr/local/epics/base-3.15.5/include        -MM -MF lexer.d  lexer.c
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-3.15.5/include/compiler/gcc -I/corvette/usr/local/epics/base-3.15.5/include/os/Linux -I/corvette/usr/local/epics/base-3.15.5/include        -MM -MF builtin.d  ../builtin.c
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-3.15.5/include/compiler/gcc -I/corvette/usr/local/epics/base-3.15.5/include/os/Linux -I/corvette/usr/local/epics/base-3.15.5/include        -MM -MF sym_table.d  ../sym_table.c
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-3.15.5/include/compiler/gcc -I/corvette/usr/local/epics/base-3.15.5/include/os/Linux -I/corvette/usr/local/epics/base-3.15.5/include        -MM -MF gen_tables.d  ../gen_tables.c
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-3.15.5/include/compiler/gcc -I/corvette/usr/local/epics/base-3.15.5/include/os/Linux -I/corvette/usr/local/epics/base-3.15.5/include        -MM -MF gen_ss_code.d  ../gen_ss_code.c
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-3.15.5/include/compiler/gcc -I/corvette/usr/local/epics/base-3.15.5/include/os/Linux -I/corvette/usr/local/epics/base-3.15.5/include        -MM -MF gen_code.d  ../gen_code.c
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-3.15.5/include/compiler/gcc -I/corvette/usr/local/epics/base-3.15.5/include/os/Linux -I/corvette/usr/local/epics/base-3.15.5/include        -MM -MF analysis.d  ../analysis.c
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-3.15.5/include/compiler/gcc -I/corvette/usr/local/epics/base-3.15.5/include/os/Linux -I/corvette/usr/local/epics/base-3.15.5/include        -MM -MF var_types.d  ../var_types.c
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-3.15.5/include/compiler/gcc -I/corvette/usr/local/epics/base-3.15.5/include/os/Linux -I/corvette/usr/local/epics/base-3.15.5/include        -MM -MF node.d  ../node.c
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-3.15.5/include/compiler/gcc -I/corvette/usr/local/epics/base-3.15.5/include/os/Linux -I/corvette/usr/local/epics/base-3.15.5/include        -MM -MF main.d  ../main.c
make[3]: Leaving directory `/corvette/home/epics/devel/seq-2.2.4/src/snc/O.linux-x86-rhel6'
Installing generic include file ../../../include/seqMain.c
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-3.15.5/include/compiler/gcc -I/corvette/usr/local/epics/base-3.15.5/include/os/Linux -I/corvette/usr/local/epics/base-3.15.5/include        -c lexer.c
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-3.15.5/include/compiler/gcc -I/corvette/usr/local/epics/base-3.15.5/include/os/Linux -I/corvette/usr/local/epics/base-3.15.5/include        -c snl.c
This is what you get for output when building src/snc:
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc'
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/makeMakefile.pl O.rhel-6-ia32 ../../..
mkdir O.Common
gmake -C O.rhel-6-ia32 -f ../Makefile TOP=../../.. \
        T_A=rhel-6-ia32 install
gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc/O.rhel-6-ia32'
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m lexer.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        lexer.o lexer.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m builtin.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        builtin.o ../builtin.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m sym_table.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        sym_table.o ../sym_table.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m gen_tables.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        gen_tables.o ../gen_tables.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m gen_ss_code.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        gen_ss_code.o ../gen_ss_code.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m gen_code.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        gen_code.o ../gen_code.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m analysis.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        analysis.o ../analysis.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m var_types.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        var_types.o ../var_types.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m node.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        node.o ../node.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m main.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        main.o ../main.c
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc/O.rhel-6-ia32'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c lexer.c
../snl.re:16:17: error: snl.h: No such file or directory
../snl.re: In function 'scan':
../snl.re:330: error: 'TOK_SLASH' undeclared (first use in this function)
Note that they are very different.  On my system gcc is being used to generate the dependency files (.d files), while on your system perl is being used.  I don't know what would cause this difference in behavior, but I suspect it is what is causing the problems?  Is this something different in a CONFIG_SITE file, either in seq-2.2.4 or in base?
From: [email protected] [mailto:[email protected]] On Behalf Of Sue Witherspoon
Sent: Tuesday, August 22, 2017 3:00 PM
To: Tech-talk
Subject: Problems building seq 2.2.4 on Linux
I am having problems building seq 2.2.4 on linux:
Redhat 6 (linux-x86)
gcc version 4.4.7
Epics 3.15.5
perl v5.10.1
This is the complete output when building.
devl06 [195]: gmake rebuild
gmake -C ./configure clean
gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure'
rm -rf O.rhel-6-ia32 O.Common
gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure'
gmake -C ./src clean
gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src'
gmake -C ./pv clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv'
gmake -C ./common clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common'
gmake -C ./seq clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq'
gmake -C ./lemon clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon'
gmake -C ./snc clean
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc'
gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src'
gmake -C ./test clean
gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test'
gmake -C ./compiler clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/compiler'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/compiler'
gmake -C ./validate clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/validate'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/validate'
gmake -C ./unit clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/unit'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/unit'
gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test'
gmake -C ./examples clean
gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples'
gmake -C ./cmdButtons clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/cmdButtons'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/cmdButtons'
gmake -C ./demo clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/demo'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/demo'
gmake -C ./johng clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/johng'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/johng'
gmake -C ./simple clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/simple'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/simple'
gmake -C ./small clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/small'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/small'
gmake -C ./pvGetAsync clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/pvGetAsync'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/pvGetAsync'
gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples'
gmake -C ./configure install
mkdir O.Common
gmake -C O.rhel-6-ia32 -f ../Makefile TOP=../.. \
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure/O.rhel-6-ia32'
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/convertRelease.pl checkRelease
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure/O.rhel-6-ia32'
gmake -C ./src install
gmake -C ./pv install
mkdir O.Common
gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv/O.rhel-6-ia32'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF pv.d  ../pv.c
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv/O.rhel-6-ia32'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../pv.c
/usr/bin/ar -rc    libpv.a        pv.o
/usr/bin/ranlib libpv.a
/usr/bin/g++ -o libpv.so.3.15.5 -shared -fPIC -Wl,-hlibpv.so.3.15.5 -L/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -L/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32           -rdynamic -m32            pv.o    -lca -lCom -Wl,-Bdynamic  -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/rhel-6-ia32/libpv.so.3.15.5
ln -s libpv.so.3.15.5 ../../../lib/rhel-6-ia32/libpv.so
Installing library ../../../lib/rhel-6-ia32/libpv.a
gmake -C ./common install
mkdir O.Common
gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common/O.rhel-6-ia32'
perl -CSD ../seq_release.pl 2.2.4 > ../O.Common/seq_release.h
Installing generated generic include file ../../../include/seq_release.h
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common/O.rhel-6-ia32'
gmake -C ./seq install
mkdir O.Common
gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq/O.rhel-6-ia32'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_queue.d  ../seq_queue.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_cmd.d  ../seq_cmd.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_qry.d  ../seq_qry.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_prog.d  ../seq_prog.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_mac.d  ../seq_mac.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_if.d  ../seq_if.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_ca.d  ../seq_ca.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_task.d  ../seq_task.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_main.d  ../seq_main.c
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq/O.rhel-6-ia32'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_main.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_task.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_ca.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_if.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_mac.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_prog.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_qry.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_cmd.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_queue.c
/usr/bin/ar -rc    libseq.a        seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o seq_cmd.o seq_queue.o
/usr/bin/ranlib libseq.a
/usr/bin/g++ -o libseq.so.3.15.5 -shared -fPIC -Wl,-hlibseq.so.3.15.5 -L/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -L/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32           -rdynamic -m32            seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o seq_cmd.o seq_queue.o    -lpv -lCom -Wl,-Bdynamic  -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/rhel-6-ia32/libseq.so.3.15.5
ln -s libseq.so.3.15.5 ../../../lib/rhel-6-ia32/libseq.so
Installing library ../../../lib/rhel-6-ia32/libseq.a
gmake -C ./lemon install
mkdir O.Common
gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon/O.rhel-6-ia32'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF lemon.d  ../lemon.c
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon/O.rhel-6-ia32'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../lemon.c
/usr/bin/g++ -o lemon -Wl,-Bstatic -L/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32           -rdynamic -m32            lemon.o     -Wl,-Bdynamic  -lpthread    -lm -lrt -ldl -lgcc
Installing created executable ../../../bin/rhel-6-ia32/lemon
gmake -C ./snc install
mkdir O.Common
../snl.re:330: error: (Each undeclared identifier is reported only once
../snl.re:330: error: for each function it appears in.)
../snl.re:331: error: 'TOK_MOD' undeclared (first use in this function)
../snl.re:285: error: 'TOK_NAME' undeclared (first use in this function)
../snl.re:287: error: 'TOK_INTCON' undeclared (first use in this function)
../snl.re:323: error: 'TOK_PERIOD' undeclared (first use in this function)
../snl.re:333: error: 'TOK_GT' undeclared (first use in this function)
../snl.re:332: error: 'TOK_LT' undeclared (first use in this function)
../snl.re:328: error: 'TOK_ADD' undeclared (first use in this function)
../snl.re:327: error: 'TOK_SUB' undeclared (first use in this function)
../snl.re:329: error: 'TOK_ASTERISK' undeclared (first use in this function)
../snl.re:324: error: 'TOK_AMPERSAND' undeclared (first use in this function)
../snl.re:334: error: 'TOK_CARET' undeclared (first use in this function)
../snl.re:335: error: 'TOK_VBAR' undeclared (first use in this function)
../snl.re:318: error: 'TOK_EQUAL' undeclared (first use in this function)
../snl.re:325: error: 'TOK_NOT' undeclared (first use in this function)
../snl.re:313: error: 'TOK_SEMICOLON' undeclared (first use in this function)
../snl.re:314: error: 'TOK_LBRACE' undeclared (first use in this function)
../snl.re:315: error: 'TOK_RBRACE' undeclared (first use in this function)
../snl.re:316: error: 'TOK_COMMA' undeclared (first use in this function)
../snl.re:317: error: 'TOK_COLON' undeclared (first use in this function)
../snl.re:319: error: 'TOK_LPAREN' undeclared (first use in this function)
../snl.re:320: error: 'TOK_RPAREN' undeclared (first use in this function)
../snl.re:321: error: 'TOK_LBRACKET' undeclared (first use in this function)
../snl.re:322: error: 'TOK_RBRACKET' undeclared (first use in this function)
../snl.re:326: error: 'TOK_TILDE' undeclared (first use in this function)
../snl.re:336: error: 'TOK_QUESTION' undeclared (first use in this function)
../snl.re:312: error: 'TOK_NE' undeclared (first use in this function)
../snl.re:311: error: 'TOK_EQ' undeclared (first use in this function)
../snl.re:308: error: 'TOK_OROR' undeclared (first use in this function)
../snl.re:301: error: 'TOK_OREQ' undeclared (first use in this function)
../snl.re:300: error: 'TOK_XOREQ' undeclared (first use in this function)
../snl.re:307: error: 'TOK_ANDAND' undeclared (first use in this function)
../snl.re:299: error: 'TOK_ANDEQ' undeclared (first use in this function)
../snl.re:296: error: 'TOK_MULEQ' undeclared (first use in this function)
../snl.re:306: error: 'TOK_POINTER' undeclared (first use in this function)
../snl.re:305: error: 'TOK_DECR' undeclared (first use in this function)
../snl.re:295: error: 'TOK_SUBEQ' undeclared (first use in this function)
../snl.re:304: error: 'TOK_INCR' undeclared (first use in this function)
../snl.re:294: error: 'TOK_ADDEQ' undeclared (first use in this function)
../snl.re:309: error: 'TOK_LE' undeclared (first use in this function)
../snl.re:303: error: 'TOK_LSHIFT' undeclared (first use in this function)
../snl.re:293: error: 'TOK_LSHEQ' undeclared (first use in this function)
../snl.re:310: error: 'TOK_GE' undeclared (first use in this function)
../snl.re:302: error: 'TOK_RSHIFT' undeclared (first use in this function)
../snl.re:292: error: 'TOK_RSHEQ' undeclared (first use in this function)
../snl.re:290: error: 'TOK_FPCON' undeclared (first use in this function)
../snl.re:270: error: 'TOK_WHILE' undeclared (first use in this function)
../snl.re:269: error: 'TOK_WHEN' undeclared (first use in this function)
../snl.re:268: error: 'TOK_VOID' undeclared (first use in this function)
../snl.re:267: error: 'TOK_UNSIGNED' undeclared (first use in this function)
../snl.re:266: error: 'TOK_UNION' undeclared (first use in this function)
../snl.re:277: error: 'TOK_UINT32T' undeclared (first use in this function)
../snl.re:275: error: 'TOK_UINT16T' undeclared (first use in this function)
../snl.re:273: error: 'TOK_UINT8T' undeclared (first use in this function)
../snl.re:264: error: 'TOK_TO' undeclared (first use in this function)
../snl.re:265: error: 'TOK_TYPENAME' undeclared (first use in this function)
../snl.re:257: error: 'TOK_SS' undeclared (first use in this function)
../snl.re:263: error: 'TOK_SYNC' undeclared (first use in this function)
../snl.re:261: error: 'TOK_SYNCQ' undeclared (first use in this function)
../snl.re:260: error: 'TOK_STRUCT' undeclared (first use in this function)
../snl.re:259: error: 'TOK_STRING' undeclared (first use in this function)
../snl.re:258: error: 'TOK_STATE' undeclared (first use in this function)
../snl.re:256: error: 'TOK_SIZEOF' undeclared (first use in this function)
../snl.re:255: error: 'TOK_SHORT' undeclared (first use in this function)
../snl.re:254: error: 'TOK_RETURN' undeclared (first use in this function)
../snl.re:253: error: 'TOK_PROGRAM' undeclared (first use in this function)
../snl.re:252: error: 'TOK_OPTION' undeclared (first use in this function)
../snl.re:251: error: 'TOK_MONITOR' undeclared (first use in this function)
../snl.re:250: error: 'TOK_LONG' undeclared (first use in this function)
../snl.re:248: error: 'TOK_IF' undeclared (first use in this function)
../snl.re:249: error: 'TOK_INT' undeclared (first use in this function)
../snl.re:272: error: 'TOK_INT8T' undeclared (first use in this function)
../snl.re:276: error: 'TOK_INT32T' undeclared (first use in this function)
../snl.re:274: error: 'TOK_INT16T' undeclared (first use in this function)
../snl.re:246: error: 'TOK_FOR' undeclared (first use in this function)
../snl.re:247: error: 'TOK_FOREIGN' undeclared (first use in this function)
../snl.re:245: error: 'TOK_FLOAT' undeclared (first use in this function)
../snl.re:244: error: 'TOK_EXIT' undeclared (first use in this function)
../snl.re:243: error: 'TOK_EVFLAG' undeclared (first use in this function)
../snl.re:242: error: 'TOK_ENUM' undeclared (first use in this function)
../snl.re:241: error: 'TOK_ENTRY' undeclared (first use in this function)
../snl.re:240: error: 'TOK_ELSE' undeclared (first use in this function)
../snl.re:239: error: 'TOK_DOUBLE' undeclared (first use in this function)
../snl.re:238: error: 'TOK_CONTINUE' undeclared (first use in this function)
../snl.re:237: error: 'TOK_CONST' undeclared (first use in this function)
../snl.re:236: error: 'TOK_CHAR' undeclared (first use in this function)
../snl.re:235: error: 'TOK_BREAK' undeclared (first use in this function)
../snl.re:234: error: 'TOK_ASSIGN' undeclared (first use in this function)
../snl.re:298: error: 'TOK_MODEQ' undeclared (first use in this function)
../snl.re:297: error: 'TOK_DIVEQ' undeclared (first use in this function)
../snl.re:358: error: 'TOK_STRCON' undeclared (first use in this function)
../snl.re:427: error: 'TOK_CCODE' undeclared (first use in this function)
gmake[3]: *** [lexer.o] Error 1
gmake[2]: *** [install.rhel-6-ia32] Error 2
gmake[1]: *** [snc.install] Error 2
gmake: *** [src.install] Error 2
devl06 [196]:
I saw a thread in tech-talk that appeared to address this but after applying the same fix to src/snc/Makefile  by adding: HDEPENDS_METHOD=MKMF, I still get the error.  snl.h is not being generated......
Any help would be most appreciated!
Sue Witherspoon
Staff Computer Scientist
Accelerator Controls Software
757-269-7579
Thomas Jefferson National Accelerator Facility
Sue Witherspoon
757-269-7579
Problems building seq 2.2.4 on Linux Sue Witherspoon
RE: Problems building seq 2.2.4 on Linux Mark Rivers
Prev: RE: Problems building seq 2.2.4 on Linux Mark Rivers
Next: RE: questions about the X-123SDD mca driver for epics Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: Trend graph partly not shown in Data Browser with Archiver Appliance Shuei YAMADA
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
