> Kay, I got the print to work...
>looks like my script is not triggered at the time
> When I put a 'Action Button' on my display that calls the script, it
> works fine..at least with the 'print' I can see where I am now.
> Any idea how I can fire my script when the 'widget' becomes 'visible' ?
> (without my having to add an action-button)
Scripts can be attached to an action, or to the widget.
1) "Execute Scipt" Action is usually attached to Action Button.
User pushes button -> Action executes the script with the 'widget'.
You can actually attach actions to any widget, then it's invoked
via the context menu of the widget.
2) Script attached to widget
.. has PVs which are by default marked to 'trigger' the script
whenever they receive a new value.
In that case the script is invoked with 'widget' and 'pvs'.
If you want to trigger a script once when a file loads, attach some dummy local PV.
The $(DID) macro is useful for creating unique PV names, so trigger it for example on "loc://$(DID)init".
You can't directly trigger a script by property changes.
Well, you could trigger a script once via a "loc://$(DID)init" PV,
and in that script you then attach a property listener:
from org.csstudio.display.builder.model import WidgetPropertyListener
class MyListener(WidgetPropertyListener):
def propertyChanged(self, prop, old_value, new_value):
print("Visibility changed...")
widget.getProperty("visible").addPropertyListener(MyListener())
But if you had to ask how to do that, you shouldn't try this, because details could change.
The more straightforward way:
How do you change the visibility in the first place?
Some (local) PV -> rule -> changes visibility?
--> Use that same PV to trigger your script.
-Kay
- CSS-4.5 : Display-Builder : getting widget's PV value Amien Crombie
- Re: CSS-4.5 : Display-Builder : getting widget's PV value Kasemir, Kay
- Re: CSS-4.5 : Display-Builder : getting widget's PV value Amien Crombie
Re: Problems building seq 2.2.4 on Linux Sue Witherspoon
<2017>
Running CSS-4.5 from Eclipse Neon Amien Crombie
<2017>
