Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: CSS-4.5 : Display-Builder : getting widget's PV value
To: Amien Crombie <acrombie@tlabs.ac.za>, EPICS Tech-Talk <tech-talk@aps.anl.gov>
Date: Thu, 24 Aug 2017 13:18:11 +0000
Hi:
> According to 'cainfo' my pv is a DBF_DOUBLE and request is DBR_DOUBLE
Well, when I try it with double or int PVs, I do get the value out via PVUtil.getDouble.
When the PV is a string, then PVUtil.getDouble returns nan.
> But I do not know how to check for output with the 'print' statement..
>I'm using Mint 18 and CSS is started >without a terminal command (am I doing something wrong?)
Just open a terminal (xterm, gnome-terminal, ...) and then start CSS from within the terminal.
=> In that terminal you can now see the print statements.
If you don't have a terminal (like on MS Windows), you can use the ScriptUtil.
​from org.csstudio.display.builder.runtime.script import ScriptUtil
ScriptUtil.getLogger().warning("Script has a problem")
==> Those messages appear in the console and also in the workspace/.metadata/.log
Finally, the ScriptUtil also allows you to open dialogs:
ScripUtil.showErrorDialog(widget, "I have a problem, pv has value " + str(pv.read()))
-Kay
Re: CSS-4.5 : Display-Builder : getting widget's PV value Amien Crombie
Re: CSS-4.5 : Display-Builder : getting widget's PV value Kasemir, Kay
Prev: Re: CSS-4.5 : Display-Builder : getting widget's PV value Amien Crombie
Next: RE: Problems building seq 2.2.4 on Linux Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: Re: CSS-4.5 : Display-Builder : getting widget's PV value Amien Crombie
ANJ, 24 Aug 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
