Hi:
What's the data type of the PV?
To debug, try adding
print(str(pv.read()))
and then check in the terminal where you started CSS for the output.
-Kay
Hi
My code :
1. from org.csstudio.display.builder.runtime.script import PVUtil, ScriptUtil
2. from org.csstudio.display.builder.model.properties import WidgetColor
3. ss = ScriptUtil.findWidgetByName(widget, "ss_range")
4. sx = ScriptUtil.findWidgetByName(widget, "rangeX")
5. pv = ScriptUtil.getPrimaryPV(sx)
6. pval = PVUtil.getDouble(pv)
7. ss.setPropertyValue("text", str(pv) + " : " + str(pval)) ##
## 'pv' returns the right pv attached to my 'spinner'. This
pv is passed via the script as '$(pv_name)'
## pval returns 'nan' although my 'spinner' displays the value (1 to 6) depending my last selected value
Thanks
Amien
- Re: CSS-4.5 : Display-Builder : getting widget's PV value Amien Crombie
- CSS-4.5 : Display-Builder : getting widget's PV value Amien Crombie
<2017>
<2017>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
