SizeX and SizeY are changed somewhat reactively from a different PV. The detector does have the capacity for a change in image size, and I have verified that the correct number of bytes is being sent by the detector.
Iain.
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Thursday, August 17, 2017 5:37 PM
> To: Iain Marcuson <[email protected]>; tech-
> [email protected] >> EPICS Tech Talk <[email protected]>
> Subject: RE: PVs controlling image size in AreaDetector
> Hi Iain,
> When your driver's writeInt32() function receives new values for SizeX and
> SizeY it needs to do something that actually causes the image size to change.
> This is typically a call to the vendor SDK to set the readout area of the
> detector. Does your detector have this capability? If not, you could
> implement it in software in your driver, but I would not recommend that.
> Rather I would suggest that you use the NDPluginROI plugin to select the
> desired sub-region.
> Here is how it is handled in the ADProsilica driver. When the writeInt32()
> function receives new values for ADBin[X,Y], ADMin[X,Y] , or ADSize[X,Y] it
> calls setGeometry which makes the calls to the vendor API to set the readout
> region of the camera.
> asynStatus prosilica::writeInt32(asynUser *pasynUser, epicsInt32 value) {
> int function = pasynUser->reason;
> int status = asynSuccess;
> tPvUint32 syncs;
> static const char *functionName = "writeInt32";
> /* Set the parameter and readback in the parameter library. This may be
> overwritten when we read back the
> * status at the end, but that's OK */
> status |= setIntegerParam(function, value);
> if ((function == ADBinX) ||
> (function == ADBinY) ||
> (function == ADMinX) ||
> (function == ADSizeX) ||
> (function == ADMinY) ||
> (function == ADSizeY)) {
> /* These commands change the chip readout geometry. We need to
> cache them and apply them in the
> * correct order */
> status |= setGeometry();
> asynStatus prosilica::setGeometry()
> int s;
> int binX, binY, minY, minX, sizeX, sizeY, maxSizeX, maxSizeY;
> static const char *functionName = "setGeometry";
> /* Get all of the current geometry parameters from the parameter library
> status |= getIntegerParam(ADBinX, &binX);
> if (binX < 1) binX = 1;
> status |= getIntegerParam(ADBinY, &binY);
> if (binY < 1) binY = 1;
> status |= getIntegerParam(ADMinX, &minX);
> status |= getIntegerParam(ADMinY, &minY);
> status |= getIntegerParam(ADSizeX, &sizeX);
> status |= getIntegerParam(ADSizeY, &sizeY);
> status |= getIntegerParam(ADMaxSizeX, &maxSizeX);
> status |= getIntegerParam(ADMaxSizeY, &maxSizeY);
> if (minX + sizeX > maxSizeX) {
> sizeX = maxSizeX - minX;
> setIntegerParam(ADSizeX, sizeX);
> if (minY + sizeY > maxSizeY) {
> sizeY = maxSizeY - minY;
> setIntegerParam(ADSizeY, sizeY);
> /* CMOS cameras don't support binning, so ignore ePvErrNotFound errors
> s = PvAttrUint32Set(this->PvHandle, "BinningX", binX);
> if (s != ePvErrNotFound) status |= s;
> s = PvAttrUint32Set(this->PvHandle, "BinningY", binY);
> if(!status){
> status |= PvAttrUint32Set(this->PvHandle, "RegionX", minX/binX);
> status |= PvAttrUint32Set(this->PvHandle, "RegionY", minY/binY);
> status |= PvAttrUint32Set(this->PvHandle, "Width", sizeX/binX);
> status |= PvAttrUint32Set(this->PvHandle, "Height", sizeY/binY);
> if (status) asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
> "%s:%s: error, status=%d\n",
> driverName, functionName, status);
> return((asynStatus)status);
> Mark
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Iain Marcuson
> Sent: Thursday, August 17, 2017 3:56 PM
> To: [email protected] >> EPICS Tech Talk
> Subject: PVs controlling image size in AreaDetector
> I am expanding on options for an AreaDetector driver I wrote. The feature I
> am trying to add is a variable image size. I have set ADMaxSizeX and
> ADMaxSizeY to the maximum for this sensor type. To change the image size,
> I am writing to SizeX and SizeY with dbPutField and setIntegerParam followed
> by callParamCallbacks(). However, the image that comes to the
> AreaDetector plugin seems to be at the maximum size I specify. What
> parameters do I change to change the output image size?
> Thank you,
> Iain Marcuson.
- RE: PVs controlling image size in AreaDetector Mark Rivers
- PVs controlling image size in AreaDetector Iain Marcuson
RE: Location of plugin attributes in HDF5 Mark Rivers
<2017>
<2017>
