Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: RE: remnant errlog thread
To: "'Johnson, Andrew N.'" <anj@aps.anl.gov>
Cc: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Fri, 11 Aug 2017 00:05:52 +0000
Hi Andrew
The persistent task is an RPC program so it is inherently multi-threaded  – each client request is essentially a new RPC thread.
So, I have one persistent CA context alive in one thread to deal with asynchronous updates then, as each RPC request comes in, to read or write a channel, I open and close a new CA connection.
I have tried to simply have one CA context and then use that in each of the client RPC calls (threads) but ca_current_context() returns NULL.
Is there some other CA call that will return the existing context?
Al
Sent: Thursday, August 10, 2017 1:52 PM
To: Al Honey
Cc: tech-talk@aps.anl.gov
Subject: Re: remnant errlog thread
Hi Al,
Have you tried keeping the CA context alive for the life of the persistent task? I don't see why you would want/need to repeatedly create and destroy the context, and it seems likely to me that's what is restarting the errlog thread, although I can't explain why (unless you are manually loading and unloading the libCom.so library as well). I think the CA library's IOC detection logic will work better if allowed to stay alive, as long as your network connection isn't going up and down as well.
HTH,
- Andrew
Sent from my iPad
On Aug 10, 2017, at 10:02 PM, Al Honey <ahoney@keck.hawaii.edu> wrote:
Hi
I have a persistent task, which opens and closes connections to various IOCs (other services as well) per client requests.
Seems that each open/close cycle causes another thread to be created and it never terminates – errlogThread.  I suspect there is one more step I need to perform when ‘closing’ a connection.
This the output from gdb for one of the remnant threads:
#0  0x00007f122a317705 in pthread_cond_wait@@GLIBC_2.3.2 ()
   from /lib64/libpthread.so.0
#1  0x00007f1227ee8099 in condWait (mutexId=0x12c6300, condId=0x12c6328)
    at ../../../src/libCom/osi/os/posix/osdEvent.c:75
#2  epicsEventWait (pevent=0x12c6300)
    at ../../../src/libCom/osi/os/posix/osdEvent.c:137
#3  0x00007f1227ed269e in errlogThread ()
    at ../../../src/libCom/error/errlog.c:491
#4  0x00007f1227ee5e6f in start_routine (arg=0x12ca420)
    at ../../../src/libCom/osi/os/posix/osdThread.c:385
#5  0x00007f122a313df5 in start_thread () from /lib64/libpthread.so.0
#6  0x00007f122950c1ad in clone () from /lib64/libc.so.6
Using R3.14.12.5
This is my process for opening a connection:
ca_context_create
ca_add_exception_event
ca_add_fd_registration
for each channel:
  ca_search_and_connect
  ca_add_masked_array_event
This is my process for closing a connection:
for each channel:
  ca_clear_event
  ca_clear_channel
ca_flush_io
ca_context_destroy
What did I miss?
Thanks for any help,
Al
Re: remnant errlog thread Johnson, Andrew N.
remnant errlog thread Al Honey
Prev: Re: remnant errlog thread Johnson, Andrew N.
Next: Re: remnant errlog thread Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
ANJ, 11 Aug 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
