That is correct. From the 3.14.12.5 application developer's guide:
Field name The field name, which must be a valid C
identifier. When include files are generated, the field name is
converted to lower case. Previous versions of EPICS required the
field name be a maximum of four characters,
but this restriction no longer applies.
Dohn
On 08/08/2017 10:26 AM, Pete Jemian
wrote:
On 8/8/2017 9:03 AM, Hogben, Colin H wrote:
OK, the test I am now using is: if the name ends with '.' and up
to four uppercase letters which are not 'VAL' then ignore the
status/severity. It seems to be working OK. As for non-IOC PVs,
I'll cross that bridge when I come to it.
Isn't it allowed for a record's field to have more than 4
characters? It's not common but the CCDImageServer (pre-area
detector software) included field names with more than 4
characters and also included one or more "." in some cases.
Pete
- CA monitoring weirdness for status/severity Hogben, Colin H
- Re: CA monitoring weirdness for status/severity Johnson, Andrew N.
- Re: CA monitoring weirdness for status/severity Hogben, Colin H
- RE: CA monitoring weirdness for status/severity Mark Rivers
- Re: CA monitoring weirdness for status/severity Pete Jemian
RE: EPICS Redundancy Penning, Joerg
Re: Replacement for dbGetPdbAddrFromLink ? Stubbs, Scott A.
<2017>
<2017>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
