1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: help for RDB of CSS
To: 梁雅翔 <[email protected]>, tech-talk <[email protected]>
Date: Tue, 8 Aug 2017 14:36:47 +0000
Hi:
From: [email protected] <[email protected]> on behalf of 梁雅翔 <[email protected]>
>  Hi everyone,
>  I am studying the database of CSS.
>  I created a database named "test" and tables named "collmn" in mysql,adding some value myself.
>  I had connected the database(the test database I created) with eclipse successfully.
>  Then I tried to use it in CSS.
>  After I type the URL "jdbc:mysql://localhost:3306/test?user=root&passowrd=123" in CSS preference, I got the message "Error connecting to archiver server......Detail:Table 'test.status' doesn't exist".
>  I am not good at the database. And it took me several weeks to connected the mysql with eclipse.
>  I want some help.
> Could someone please tell me how to do it next? It is better that you have some example.
Right, there better be examples.
Check the CSS docbook, http://cs-studio.sourceforge.net/docbook/css_book.pdf, especially the chapters "10 Relational Database" and "11 Archive System".
To elaborate, from what you write I understand that you created a database named "test" and tables named "collmn" in mysql.
You can create many databases: A database with tables for names and addresses, flowers, your CD or MP3 collection.
CSS does not include tools to browse just any generic database.
The CSS Data Browser supports a very specific database with archived control system data.
The schema is described in the docbook.
The actual MySQL schema can be found in
https://github.com/ControlSystemStudio/cs-studio/blob/master/applications/archive/archive-plugins/org.csstudio.archive.rdb/dbd/mysql_schema.txt
As you can see in the schema, there needs to be a table named 'status':
# Status mapping of status ID to string
DROP TABLE IF EXISTS status;
CREATE TABLE IF NOT EXISTS status
   status_id INT UNSIGNED PRIMARY KEY AUTO_INCREMENT,
   name VARCHAR(100) NOT NULL UNIQUE
INSERT INTO status (name) VALUES ('OK'), ('disconnected');
SELECT * FROM status;
The CSS code for reading archived data expects to find such a "status" table, but your database doesn't include one, so you get the error message
Kay
help for RDB of CSS 梁雅翔
Prev: Re: CA monitoring weirdness for status/severity Hogben, Colin H
Next: Re: CA monitoring weirdness for status/severity Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: help for RDB of CSS 梁雅翔
Next: agilent 34972a Pierrick Hanlet
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
