Hi Ricardo,
I suspect you may have problems with the order in which you added files to your application dbd file. It looks like your driver is based on areaDetector. Does your IOC Makefile look like the following one from simDetector:
corvette:simDetectorIOC/simDetectorApp/src>more Makefile
TOP=../..
include $(TOP)/configure/CONFIG
# ADD MACRO DEFINITIONS AFTER THIS LINE
# The following gets rid of the -fno-implicit-templates flag on vxWorks,
# so we get automatic template instantiation.
# This is what we want for miscellaneous/asynPortDriver.cpp
ifeq (vxWorks,$(findstring vxWorks, $(T_A)))
CODE_CXXFLAGS=
endif
PROD_NAME = simDetectorApp
PROD_IOC = $(PROD_NAME)
# <name>.dbd will be created from <name>Include.dbd
DBD += $(PROD_NAME).dbd
$(PROD_NAME)_DBD += simDetectorSupport.dbd
# <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd
PROD_SRCS_DEFAULT += $(PROD_NAME)_registerRecordDeviceDriver.cpp $(PROD_NAME)Main.cpp
PROD_SRCS_vxWorks += $(PROD_NAME)_registerRecordDeviceDriver.cpp
PROD_LIBS += simDetector
include $(ADCORE)/ADApp/commonDriverMakefile
include $(TOP)/configure/RULES
# ADD RULES AFTER THIS LINE
Note that it adds simDetectorSupport.dbd and then " include $(ADCORE)/ADApp/commonDriverMakefile". commonDriverMakefile adds the other dbd files required to build the application.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Ricardo Herrero
Sent: Saturday, August 05, 2017 11:25 AM
To: [email protected]
Subject: Compile Warning:"Device using undefined record type 'stringin', place-holder created
Hello,
I´m cross compiling from x86_64 linux to an ARM processor. I thought it
was ok, as the executable was properly built. However I got this error
when I was executing my IOC in the ARM processor:
dbLoadDatabase
"/opt/epics/support/areaDetector/ADHA_1D/iocs/HA1DIOC/dbd/hpsfpga1dtest.dbd"
Declaration of recordtype(mbboDirect) preceeded full definition.
Error at or before "}" in file
line 119
hpsfpga1dtest_registerRecordDeviceDriver pdbbase
Warning: IOC is booting with TOP =
"/opt/epics/support/areaDetector/ADHA_1D/iocs/HA1DIOC"
but was built with TOP =
"/home/rherrero/Documents/build/areadetector-bf48e03/ADHA_1D/iocs/HA1DIOC"
registerRecordDeviceDriver failed asyn
registerRecordDeviceDriver failed busy
Then I looked at strange messages from compilation and I have found
this:
Device using undefined record type 'stringout', place-holder created
Device using undefined record type 'waveform', place-holder created
Device using undefined record type 'ai', place-holder created
Device using undefined record type 'ao', place-holder created
Device using undefined record type 'bi', place-holder created
Device using undefined record type 'bo', place-holder created
Device using undefined record type 'mbbi', place-holder created
Device using undefined record type 'mbbo', place-holder created
Device using undefined record type 'longin', place-holder created
Device using undefined record type 'longout', place-holder created
Device using undefined record type 'mbbiDirect', place-holder created
Device using undefined record type 'mbboDirect', place-holder created
It´s not very clear to me what´s happening here. I thought I have set up
properly asyn path and busy path. What do you think I should check now?
Maybe Makefile is not correct?
To include asyn in my makefile I used: ha1d_LIBS += asyn
Thanks for your help!!
Ricardo
Doctorando i2a2
Jefe de Area de Ingeniería de Sistemas - CEH- CEDEX
- Compile Warning:"Device using undefined record type 'stringin', place-holder created Ricardo Herrero
CA monitoring weirdness for status/severity Hogben, Colin H
<2017>
<2017>
