Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Webopi issue with Text Update widget rule
From: "Petrella, Nicoletta" <Nicoletta.Petrella@ukaea.uk>
To: "'tech-talk@aps.anl.gov'" <tech-talk@aps.anl.gov>, "'cs-studio-users@lists.sourceforge.net'" <cs-studio-users@lists.sourceforge.net>
Date: Fri, 4 Aug 2017 08:53:44 +0000
Dear all,
I’m prototyping a simple CS-Studio Boy OPI and I would like the OPI be accessible via webopi, but I’m experiencing webopi strange behaviour.
I’m interested in seeing in the BOY and webopi screens the status Open/Close of a certain area and some other PV values.
I have a softioc to simulate some process variables to exercise the OPI.  To simulate the state of the area I use a calc record which takes values 0 and 1.
record(calc, "SIM_CID_AREA_status")
field(SCAN, "10 second")
field(CALC, "A<1?A+1:0")
field(INPA, "SIM_CID_AREA_status")
In the OPI I then have a Text Update widget with a rule on the text to be displayed to be Area Open or Area Close depending on the value of my simulated PV SIM_CID_AREA_status. All works fine in the BOY screen, but in the webopi the text is not always displayed. Randomly sometimes I correctly get displayed the text (Area Open or Area Close ) and sometimes I get displayed numbers (0,1).
Please could you help me to understand why the webopi does not always show the text I specify in the rule and to solve the issue as rules should be supported by webOPI?
I understand I could have a string record instead, but I’m trying to figure out why everything works OK in BOY and I have issues with webopi.
Also it seems I cannot see label widgets placed over a text update widgets in the webopi screen, but this is OK in the BOY screen. My current solution is to have a label widget placed on the top of  the text update widget as below
or a second text update widget without setting a PV over the main text update widget.
Please could you also explain me how to have a label always visible in the webopi screen, also if it is over a test update widget?
Many thanks.
Kind regards,
Nicoletta
Nicoletta Petrella
Instrumentation and Control Engineer / CCFE CODAS & IT Dept
K1/1/44a
United Kingdom Atomic Energy Authority
Culham Science Centre
Abingdon
Oxfordshire
OX14 3DB
Tel: 01235 464739
Mob: +44 (0) 7964 668742
Re: Webopi issue with Text Update widget rule Kasemir, Kay
Prev: Re: XYgraph pv_name Amien Crombie
Next: Re: help - writing a table column from OPI BOY to PV Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Job openings at ITER Ralph Lange
Next: Re: Webopi issue with Text Update widget rule Kasemir, Kay
ANJ, 04 Aug 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
