Hi Matt, No worries on the timing of your reply, the information is extremely helpful. I wasn't even aware of (nor was I informed of from Andor) the /tmp/atdebug.log file. I will look through this for messages that match up with times we see AT_ERR_NODATA errors. It looks like it gets wiped every r The errors are very sporadic for us. We can go several million grabs before we see an error but can also sometimes get errors within less than a few thousand images. I've tried retriggering (we're using software triggering) with no luck. However, stopping and starting acquisition does appear to allow us to work around the issue. I will let you know if I find similar atdebug messages when we encounter the error again. Thanks again for your help. -- Brett On Wed, Aug 2, 2017 at 10:55 AM, Pearson, Matthew R. <[email protected]> wrote: Hi Brett,
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
