1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Using CSS ViewParts in Eclipse 4
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 1 Aug 2017 12:51:36 +0000
Hi:
> I’m trying to write an Eclipse 4 application using EPICS and CSS.
> From inspection of the code, CSS’s views use the Eclipse 3.x compatibility layer; they inherit from ViewPart and call creatPartControl() to build the view.
> Elements of the Eclipse 4 application model on the other hand use > annotations (i.e.  @PostConstruct) to do the same.
> If I try and use a CSS ViewPart in my Eclipse 4 application, I typically get nullPointerExceptions where the CSS class tries to access the Eclipse  3.x API (e.g. getSite()).
>  Does anyone have any advice on how I can get around this issue  to use CSS views in my Eclipse 4 application?
You can have POD-type contributions with @PostConstruct etc.
Just search for @PostConstruct in the CSS sources and you'll find the Clock plugin as an example.
(https://github.com/ControlSystemStudio/cs-studio/blob/master/applications/apputil/apputil-plugins/org.csstudio.utility.clock/src/org/csstudio/utility/clock/ClockView.java )
The associated plugin.xml registers that POD as an "e4view" (https://github.com/ControlSystemStudio/cs-studio/blob/master/applications/apputil/apputil-plugins/org.csstudio.utility.clock/plugin.xml#L10).
For what it's worth, the "compatibility layer" is somewhat misnamed.
RCP is not going away, E4 is not replacing it.
A better way to describe it:
E4 is a low-level model-based description of parts, menues etc. which are then rendered by SWT.
That's great for building a new standalone browser for your DVD collection, or for a clock.
For an application you typically also want online help, preference UI, file navigator, ..
That's what RCP adds on top of E4.
The "compatibility layer" would better be named "rich application layer" or "workspace  and workbench layer".
The Eclipse IDE for example will continue to use it.
See also "Tips and tricks for your Eclipse 4 migration." on https://www.eclipsecon.org/na2016/conference/session-slides
-Kay
Using CSS ViewParts in Eclipse 4 adrian.potter
Prev: Using CSS ViewParts in Eclipse 4 adrian.potter
Next: RE: EPICS Redundancy Penning, Joerg
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: XYgraph pv_name Amien Crombie
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
