1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: Creating an error counter
From: "Flewellen-Gore, Andrew (US)" <[email protected]>
To: "Mooney, Tim M." <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 20 Jul 2017 21:09:00 +0000
Thanks for your responses!
Tim,
It does not process normally and I can’t get manual processing to work. When I disconnect the SEM, the CALC record does increment once, and prcesses. The record that causes the triggering, however, does not print out that it processed with $(P):$(R):DEBUG:LISTEN.TPRO set to 1.
I changed my code to cut out the stream device support to see if I could get the link and the counter to work, and had success. See code below.
record(stringin,$(P):$(R):DEBUG:LISTEN)  {
    field(DESC,"Holds last SEM error")
    field(TPRO,"1")
    field(SCAN, ".1 second")
    field(FLNK,"$(P):$(R):DEBUG:COUNTER")
    field(INP, "dummy string")
record(calc,$(P):$(R):DEBUG:COUNTER)  {
    field(DESC,"Counter of # of errors")
    field(SCAN,"Passive")
    field(TPRO,"1")
    field(CALC,"VAL+1")
cid:image001.png@01D30179.2FDFE7F0
It seems like too many errors might be coming in from the SEM too fast for stream device to operate as expected. I’m getting around 150 errors per second right now. Also, it may be important to note that we are actually interfacing with a hardware emulator that allows us to communicate with a virtual SEM. Unfortunately, something is wrong with the coding of the emulator so it dumps lots of errors through the debug port, complaining that the emulator cannot establish full functionality due to a bad object reference. This should not have effect on the connection quality, but does dump a lot of errors onto us. It seems like the sheer message speed might be the problem since the LISTEN and COUNTER PVs don’t ever report that they finish processing while the SEM is connected and sending errors quickly. It is strange to me though, that the LISTEN record is able to process to the point of getting the correct error messages, at least at a surface glance, since caget(…LISTEN) returns an error with a sensible timestamp at any given time.
-Andrew
Sent: Thursday, July 20, 2017 13:35
To: Flewellen-Gore, Andrew (US) <[email protected]>; [email protected]
Subject: Re: Creating an error counter
*** WARNING ***
EXTERNAL EMAIL -- This message originates from outside our organization.
Hi Andrew,
That calc record does increment on my system.  Does it increment for you if you process it manually?  Can you verify that the forward link actually is causing the calc record to process, by setting $(P):$(R):DEBUG:COUNTER.TPRO to 1, and watching the IOC console?
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (
www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] <[email protected]> on behalf of Flewellen-Gore, Andrew (US) <[email protected]>
Sent: Thursday, July 20, 2017 11:49:07 AM
To:
[email protected]
Subject: Creating an error counter
Hello, and thanks for reading,
I’m having trouble keeping a counter for the number of errors coming in from an electron microscope (SEM). I’m using the Stream device driver to listen to incoming messages from the SEM, and when a message matches a certain format that identifies it as an error message, the PV processes and stores the new error message, overwriting the last. When this happens I would like to have a second record process and increment a counter, so that I can keep track of the number of error messages coming in.
My current setup gets the most recent error message correctly, but does not correctly increment the counter (the counter stays at zero). Here is the relevant code from the record definition file.
record(waveform,$(P):$(R):DEBUG:LISTEN)  {
    field(DTYP,"stream")
    field(NELM,"1000")
    field(FTVL,"CHAR")
    field(SCAN,"I/O Intr")
    field(INP, "@devhardware.proto debugListen() L5 0")
    field(INPA,"1")
    field(CALC,"VAL+A")
When the first record processes due to an interrupt on a received error message, it is supposed to forward-link the calc record to process, causing an increment to the counter.
Any help or insight is appreciated.
-Andrew
Re: Creating an error counter Mooney, Tim M.
Prev: Re: Creating an error counter Ralph Lange
Next: autosave R5-8 release Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: Creating an error counter Mooney, Tim M.
Next: Re: Creating an error counter Southern, Tim
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
