1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Autosave for waveform with 1 element
To: "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 12 Jul 2017 18:39:36 +0000
Hi Andrew,
re...
> However I don't know whether you really need to reimplement the
> functionality in dbAccess.c:dbPut() inside autosave, why aren't you just
> using that to write the field values in pass 1? I can understand that it
> won't work in pass 0 (especially for fields that are marked special),
> but after the records have been initialized the dbPut() routine should
> work properly. If it doesn't I would like to know why and try fixing it
> in Base.
Awesome!  I did this, and it works.  I don't really like the possibility that special() might be called, but I can't think of an actual problem it would cause.
This change removes the only call to dbFastPutConvertRoutine() in autosave, so I guess that could come off Michael Davidsaver's list.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Sent: Wednesday, July 12, 2017 11:25:56 AM
To: Mooney, Tim M.; [email protected]
Hi Tim,
On 07/11/2017 08:29 PM, Mooney, Tim M. wrote:
> This code is called from two initHooks: initHookAfterInitDevSup (before
> record init) and initHookAfterInitDatabase (after record and device
> init).  DBF_NOACCESS fields, including arrays, are skipped in the first
> call.
I checked out the latest version of autosave to look at what you're
doing. As I said yesterday and contrary to the comment in dbrestore.c
it's not actually record initialization that changes the field type, the
value of pflddes->field_type never changes (it holds the metadata for
the record type as a whole, not for individual record instances), but
the call to prset->cvt_dbaddr() inside dbNameToAddr() that modifies your
paddr->field_type value. It also sets any other members of paddr that
need updating at runtime.
The other relevant RSET routine is prset->get_array_info() which in
newer versions of Base can also adjust paddr->pfield to permit
double-buffering of the array data, and I now think this is where the
autosave code needs to change slightly. More below...
> I don't have a way of distinguishing arrays of one element from scalars.
> At save time, I'm using ca_element_count() to determine the number of
> array elements, and treating PVs with one element as scalars.
Your code in SR_put_array_values() is calling prset->get_array_info(),
but in scalar_restore() you don't call it, so in the new versions of the
aao and waveform record code where paddr->pfield is now being set in the
get_array_info() routine the scalar_restore() method is not writing
single-element array data to the right place. For a field whose
pflddes->field_type is DBF_NOACCESS you *must* now use the record type's
prset->get_array_info() method to update your paddr->pfield pointer, and
you should probably also call prset->put_array_info() afterwards too.
These should be safe to call in older versions of Base, so I don't think
you'll need version-specific code.
in Base.
> At boot-time restore, I'm using the text that was written at save time
> to tell me how to restore the PV's value.
That should be OK.
> I also noticed that paddr->pfield was being set in different calls
> - get_array_info() or cvt_dbaddr() -  and that this changed from
> 3.14.12.5 to 3.15.5.  But when I pulled the 3.14.12.5 version of the
> waveform record into 3.15.5 and it didn't fix the problem, I assumed
> this was not the source of the problem.  Maybe I should try again, more
> carefully this time.
It's not just the record type changes that matter, what you're trying
there probably isn't going to solve the problem.
- Andrew
Re: Autosave for waveform with 1 element Andrew Johnson
Autosave for waveform with 1 element Paduan Donadio, Marcio
Re: Autosave for waveform with 1 element Mooney, Tim M.
Prev: Re: Autosave for waveform with 1 element Andrew Johnson
Next: Re: Autosave for waveform with 1 element Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
