1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: error during build
To: "Heesterman, Peter J" <[email protected]>, 'Stefen Paul' <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 12 Jul 2017 10:45:58 +0200
The packaget is either called
readline-devel or libreadline-dev
That depends on your Linux installation.
On 12/07/17 10:06, Heesterman, Peter J wrote:
Hi Stefan,
You need to install the ‘readline’ library, see https://stackoverflow.com/questions/23085076/readline-readline-h-file-not-found
Cheers,
Peter.
*From:*[email protected] [mailto:[email protected]] *On Behalf Of *Stefen Paul
*Sent:* 12 July 2017 08:12
*To:* EPICS Tech Talk
*Subject:* Re: error during build
I installed g++ and moved ahead from this point.
But now the build is stopping with following error:
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/epicsReadline.c ../../../src/libCom/osi/os/default/epicsReadline.c:79:31: fatal error: readline/readline.h: No such file or directory
  #include <readline/readline.h>
compilation terminated.
make[3]: *** [epicsReadline.o] Error 1
make[3]: Leaving directory `/home/opal/epics/base/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/opal/epics/base/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/home/opal/epics/base/src'
make: *** [src.install] Error 2
Stefen
On Tue, Jul 4, 2017 at 7:10 PM, Mark Rivers <[email protected] <mailto:[email protected]>> wrote:
Hi Stefen,
It looks like you may need to install the package with g++. What happens if you type these 3 commands:
g++
which g++
/usr/bin/g++
On my Centos 7 system g++ would be installed with the command
sudo yum install gcc-c++
From: [email protected] <mailto:[email protected]> [[email protected] <mailto:[email protected]>] on behalf of Stefen Paul [[email protected] <mailto:[email protected]>]
Sent: Tuesday, July 04, 2017 8:33 AM
To: EPICS Tech Talk
Subject: error during build
Hi All,
I am trying to build EPICS on a fresh and upgraded Linux installation.
When I run the make command, the process is stopping with following error messages towards the end
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/ring/epicsRingPointer.cpp
make[3]: /usr/bin/g++: Command not found
make[3]: *** [epicsRingPointer.o] Error 127
opal@system1:~/epics/base$
Any clues as to whats going wrong ?
Stefen
Stefen
error during build Stefen Paul
RE: error during build Mark Rivers
Re: error during build Stefen Paul
RE: error during build Heesterman, Peter J
Prev: RE: error during build Heesterman, Peter J
Next: CA gateway with systemd Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: Plotting X-Y Data from the archive in CSS John . Holt
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
