1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: CSS Text entry values not updating on PV change
To: Iain Marcuson <[email protected]>, "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Wed, 5 Jul 2017 13:47:27 +0000
Hi Iain,
Is your driver based on asyn?
If so, your setter records you can add the info tag asyn:READBACK.  This will force the setter (output) records to update their values based on a callback from the driver.  It is documented here:
http://www.aps.anl.gov/epics/modules/soft/asyn/R4-31/asynDriver.html#genericEpicsSupport
From: [email protected] [[email protected]] on behalf of Iain Marcuson [[email protected]]
Sent: Wednesday, July 05, 2017 8:40 AM
To: [email protected] >> EPICS Tech Talk
Subject: CSS Text entry values not updating on PV change
I am trying to update some text entry boxes with values from the IOC.  The controller ultimately sends and receives many parameters as a single block.  I have set up the IOC to have separate getters and setters that batch the values and transmit them.  I have text entry widgets for the setters and text update widgets for the getters.  What I would like to do on a Get operation is populate the setter widgets with the getter values.  I have tested this with caget and can see that the PV values are populated when I do a get, but the values in the CSS BOY GUI do not update.  Is there some way to populate the text entry widgets from the PV?
Thank you,
Iain.
RE: CSS Text entry values not updating on PV change Iain Marcuson
Prev: CSS Text entry values not updating on PV change Iain Marcuson
Next: RE: CSS Text entry values not updating on PV change Iain Marcuson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
