Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: RE: error during build
To: Stefen Paul <stefen4114@gmail.com>, EPICS Tech Talk <tech-talk@aps.anl.gov>
Date: Tue, 4 Jul 2017 13:40:09 +0000
Hi Stefen,
It looks like you may need to install the package with g++.  What happens if you type these 3 commands:
g++
which g++
/usr/bin/g++
On my Centos 7 system g++ would be installed with the command
sudo yum install gcc-c++
From: tech-talk-bounces@aps.anl.gov [tech-talk-bounces@aps.anl.gov] on behalf of Stefen Paul [stefen4114@gmail.com]
Sent: Tuesday, July 04, 2017 8:33 AM
To: EPICS Tech Talk
Subject: error during build
Hi All,
I am trying to build EPICS on a fresh and upgraded Linux installation.
When I run the make command, the process is stopping with following error messages towards the end
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/ring/epicsRingPointer.cpp
make[3]: /usr/bin/g++: Command not found
make[3]: *** [epicsRingPointer.o] Error 127
make[3]: Leaving directory `/home/opal/epics/base/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/opal/epics/base/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/home/opal/epics/base/src'
make: *** [src.install] Error 2
opal@system1:~/epics/base-linux$
Any clues as to whats going wrong ?
Stefen
Re: error during build Stefen Paul
Prev: error during build Stefen Paul
Next: Plotting X-Y Data from the archive in CSS John . Holt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: Re: error during build Stefen Paul
ANJ, 12 Jul 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
