Hi Liang yx,
If you would like to install jca because of the archiver appliance
installation, you can ignore the installation of jca.
What you need is the EPICS base installation, and let the archiver
appliance know where your EPICS base is.
you should define LD_LIBRARY_PATH as well.
Best,
Han
On 06/23/2017 05:06 PM, 梁雅翔 wrote:
Hi all,
I met some question when I install the channel archiver.
I should install the caj first as the web said: http://slacmshankar.github.io/epicsarchiver_docs/details.html.
The Download lind was broken, the Sourceforge link took me to "Java Channel Access", does JCA was CAJ ?
then when I try to install JCA (Java Channel Access), I met the question.
my jca was put in /base/extension/src and jdk was installed.
Feora 23, linux86_64, base 3.1.12.5
Here is my output of ant:
[root@localhost config]# cd ..
[root@localhost jca2.1.2]# ant
Buildfile: /opt/epics/extensions/src/jca2.1.2/build.xml
build.core.java:
[echo] Building core classes
[javac] /opt/epics/extensions/src/jca2.1.2/build.xml:143: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
[javac] Compiling 112 source files to /opt/epics/extensions/src/jca2.1.2/O.core
[javac] /opt/epics/extensions/src/jca2.1.2/src/core/gov/aps/jca/dbr/Severity.java:4: error: unmappable character for encoding UTF8
[javac] * Created on 15 d�cembre 2003, 09:45
[javac] ^
[javac] /opt/epics/extensions/src/jca2.1.2/src/core/gov/aps/jca/dbr/Status.java:4: error: unmappable character for encoding UTF8
[javac] * Created on 15 d�cembre 2003, 09:32
[javac] ^
[javac] 2 errors
BUILD FAILED
/opt/epics/extensions/src/jca2.1.2/build.xml:143: Compile failed; see the compiler error output for details.
Total time: 0 seconds
Liang yx
- jca question 梁雅翔
Re: jca question Jeong Han Lee
Area Detector and high performance NVME devices Mark S. Engbretson
<2017>
Re: Could you help us how we can compile an EPICS IOC with vxWorks6.8. Thanks! Andrew Johnson
<2017>
