1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem compiling EPICS ioc with libusb
Cc: Sam de Jong <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 23 Jun 2017 11:06:39 -0400
Right.
I was just able to compile successfully with these in my Makefile:
testSupport_SRCS += DI-2108-P.cpp
testSupport_SYS_LIBS += usb-1.0
Also, your added source files DI-2108-P.cpp and DI-2108-P-h need to be in the .../testApp/src directory.
Here is the whole  Makefile:
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS BELOW HERE
# xxxRecord.h will be created from xxxRecord.dbd
DBDINC += xxxRecord
# Install xxxSupport.dbd into <top>/dbd
DBD += xxxSupport.dbd
# Build an IOC support library
LIBRARY_IOC += testSupport
# Compile and add the code to the support library
testSupport_SRCS += xxxRecord.c
testSupport_SRCS += devXxxSoft.c
# Link locally-provided code into the support library,
# rather than directly into the IOC application.
# This is required for Windows DLL builds.
testSupport_SRCS += dbSubExample.c
testSupport_SRCS += testHello.c
testSupport_SRCS += initTrace.c
testSupport_LIBS += $(EPICS_BASE_IOC_LIBS)
# Build the IOC application
PROD_IOC = test
# test.dbd will be created and installed
DBD += test.dbd
# test.dbd will include these files:
test_DBD += base.dbd
test_DBD += xxxSupport.dbd
test_DBD += dbSubExample.dbd
test_DBD += testHello.dbd
test_DBD += initTrace.dbd
# test_registerRecordDeviceDriver.cpp derives from test.dbd
test_SRCS += test_registerRecordDeviceDriver.cpp
# Build the main IOC entry point where needed
test_SRCS_DEFAULT += testMain.cpp
test_SRCS_vxWorks += -nil-
# Add support from base/src/vxWorks if needed
#test_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
# Link in the code from our support library
test_LIBS += testSupport
On Fri, Jun 23, 2017 at 4:45 AM, Hinko Kocevar <[email protected]> wrote:
I think he needs
test_SYS_LIBS += usb-1.0
'Cause header file pulls in libisb-1.0/libusb.h
Cheers,
Hinko
On Fri, 23 Jun 2017 at 01:21, Mark Rivers <[email protected]> wrote:
You need to add libusb to testApp/src/Makefile like this:
From: [email protected] [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Sam de Jong
Sent: Thursday, June 22, 2017 6:17 PM
To: [email protected]
Subject: Problem compiling EPICS ioc with libusb
Hello EPICS tech-talk,
    I am trying to compile an EPICS IOC with libusb included (I am on a linux platform running ubuntu 14.04 and EPICS base 3.14-3.14.12.3 ).
    I created the ioc using
    makeBaseApp.pl -t example test
    makeBaseApp.pl -t example -i -a linux-x86_64 test
and was able to run make with no issues.
I added the header files for a class I created which interfaces with a usb device (these are included in this email) by adding this line to /testAPP/src/testMain.cpp:
    #include "DI-2108-P.cpp"
when I try to make, I get this output:
make -C ./configure install
make[1]: Entering directory `/media/Extra_Space/work/testIOC/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
make[2]: Entering directory `/media/Extra_Space/work/testIOC/configure/O.linux-x86_64'
perl ../../../epics/epics3.14-3.14.12.3/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory `/media/Extra_Space/work/testIOC/configure/O.linux-x86_64'
make[1]: Leaving directory `/media/Extra_Space/work/testIOC/configure'
make -C ./testApp install
make[1]: Entering directory `/media/Extra_Space/work/testIOC/testApp'
make -C ./src install
make[2]: Entering directory `/media/Extra_Space/work/testIOC/testApp/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[3]: Entering directory `/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64'
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../../../epics/epics3.14-3.14.12.3/include/os/Linux -I../../../../epics/epics3.14-3.14.12.3/include       ../testMain.cpp
In file included from ../testMain.cpp:14:0:
../DI-2108-P.cpp: In member function ‘std::vector<double> DI_2108_P::getReadings()’:
../DI-2108-P.cpp:202:7: warning: variable ‘r’ set but not used [-Wunused-but-set-variable]
   int r; //for return values
/usr/bin/g++ -o test  -L/media/Extra_Space/work/epics/epics3.14-3.14.12.3/lib/linux-x86_64 -L/media/Extra_Space/work/testIOC/lib/linux-x86_64        -m64              test_registerRecordDeviceDriver.o testMain.o    -ltestSupport -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
testMain.o: In function `DI_2108_P::Initialize()':
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:37: undefined reference to `libusb_init'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:42: undefined reference to `libusb_set_debug'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:44: undefined reference to `libusb_get_device_list'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:51: undefined reference to `libusb_open_device_with_vid_pid'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:56: undefined reference to `libusb_free_device_list'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:58: undefined reference to `libusb_kernel_driver_active'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:63: undefined reference to `libusb_claim_interface'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:60: undefined reference to `libusb_detach_kernel_driver'
testMain.o: In function `DI_2108_P::close()':
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:82: undefined reference to `libusb_release_interface'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:89: undefined reference to `libusb_close'
testMain.o: In function `DI_2108_P::sendMessage(std::string)':
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:114: undefined reference to `libusb_bulk_transfer'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:118: undefined reference to `libusb_bulk_transfer'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:120: undefined reference to `libusb_strerror'
testMain.o: In function `DI_2108_P::getReadings()':
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:208: undefined reference to `libusb_bulk_transfer'
testMain.o: In function `DI_2108_P::reset()':
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:74: undefined reference to `libusb_reset_device'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:90: undefined reference to `libusb_exit'
collect2: error: ld returned 1 exit status
make[3]: *** [test] Error 1
make[3]: Leaving directory `/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/media/Extra_Space/work/testIOC/testApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/media/Extra_Space/work/testIOC/testApp'
make: *** [testApp.install] Error 2
Do you have any idea what might be causing this issue? I've tried googling around and haven't found anything helpful.
Thank you for your assistance,
-Sam de Jong
.. the more I see the less I believe.., AE AoR
Mike Westfall
Control Systems Software Engineer
Problem compiling EPICS ioc with libusb Sam de Jong
RE: Problem compiling EPICS ioc with libusb Mark Rivers
Re: Problem compiling EPICS ioc with libusb Hinko Kocevar
Prev: jca question 梁雅翔
Next: RE: Problem compiling EPICS ioc with libusb Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: Problem compiling EPICS ioc with libusb Hinko Kocevar
Next: Re: Problem compiling EPICS ioc with libusb Sam de Jong
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
