Hi all,
I met some question when I install the channel archiver.
I should install the caj first as the web said: http://slacmshankar.github.io/epicsarchiver_docs/details.html.
The Download lind was broken, the Sourceforge link took me to "Java Channel Access", does JCA was CAJ ?
then when I try to install JCA (Java Channel Access), I met the question.
my jca was put in /base/extension/src and jdk was installed.
Feora 23, linux86_64, base 3.1.12.5
Here is my output of ant:
[root@localhost config]# cd ..
[root@localhost jca2.1.2]# ant
Buildfile: /opt/epics/extensions/src/jca2.1.2/build.xml
build.core.java:
[echo] Building core classes
[javac] /opt/epics/extensions/src/jca2.1.2/build.xml:143: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
[javac] Compiling 112 source files to /opt/epics/extensions/src/jca2.1.2/O.core
[javac] /opt/epics/extensions/src/jca2.1.2/src/core/gov/aps/jca/dbr/Severity.java:4: error: unmappable character for encoding UTF8
[javac] * Created on 15 d�cembre 2003, 09:45
[javac] ^
[javac] /opt/epics/extensions/src/jca2.1.2/src/core/gov/aps/jca/dbr/Status.java:4: error: unmappable character for encoding UTF8
[javac] * Created on 15 d�cembre 2003, 09:32
[javac] ^
[javac] 2 errors
BUILD FAILED
/opt/epics/extensions/src/jca2.1.2/build.xml:143: Compile failed; see the compiler error output for details.
Total time: 0 seconds
Liang yx
- Re: jca question J. Lewis Muir
- Re: jca question Jeong Han Lee
RE: modbus write 2 16 bits holding registers with modbus function 16 Mark Rivers
Re: Problem compiling EPICS ioc with libusb Michael Westfall
<2017>
Re: modbus write 2 16 bits holding registers with modbus function 16 Claudio Lambert
<2017>
