Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: waveform arrays within SNL
To: tech-talk@aps.anl.gov
Date: Tue, 20 Jun 2017 16:25:37 -0400
You need to define the SNL variable: locations as an integer array.
#define ARRAY_SIZE 4
int locations[ARRAY_SIZE];
assign locations to "{tel}{instr}:{mech}:locations";
monitor locations;  // This tells the SNL to keep track of changes to assigned PV
There is more info on the EPICS Sequencer online documentation
http://www-csr.bessy.de/control/SoftDist/sequencer/Tutorial.html#arrays-of-variables
Here is an example code that writes values of a list of PVs to a waveform:
#define DTL_SET 10
double dtl_set[DTL_SET];
assign dtl_set to
    "DTL_Diag:BLM130{Loss}",
    "DTL_Diag:BLM160{Loss}",
    "DTL_Diag:BLM224{Loss}",
    "DTL_Diag:BLM248{Loss}",
    "DTL_Diag:BLM317{Loss}",
    "DTL_Diag:BLM334{Loss}",
    "DTL_Diag:BLM414{Loss}",
    "DTL_Diag:BLM428{Loss}",
    "DTL_Diag:BLM512{Loss}",
    "DTL_Diag:BLM524{Loss}"
monitor dtl_set;
double dtl_val[DTL_SET];
assign dtl_val to "dtl_set:wf";
double charge;
assign charge to "BCM25:Q";
monitor charge;
ss lossWFgen
   state update
          when(delay(2.0))
          // Caculate loss in rad/coulomb and write to waveform array
          for (i=0; i<DTL_SET; ++i)
                pvGet(dtl_set[i]);
                if (dtl_set[i] < 0){ dtl_set[i] = 0;}
                dtl_val[i] = dtl_set[i] / charge;
          pvPut(dtl_val);
          }state update
Tim
On 6/20/17 3:22 PM, Al Honey wrote:
Hi
I cannot find an explicit example in regards to accessing the element values in a waveform array from within an SNL sequencer.
Does anybody have experience doing so?
Can’t seem to do this:
int locations;
assign locations to "{tel}{instr}:{mech}:locations";  // where locations is a waveform record with an integer array.
int locs[4] = {0,300,600,900};
        pvGet( locations );
        locs = locations;               // is the declaration for locations (above) correct?
error: incompatible types when assigning to type int[4] from type int *
         locs = locations;
This fails too:
         locs[0] = locations[0];
I guess I’m ignorant in regards to accessing the array values in the record.
Also, is it necessary to escape to C in order to update the elements in a waveform string record?
Thanks for any advice you have
Al
waveform arrays within SNL Al Honey
Prev: RE: waveform arrays within SNL Mark Rivers
Next: Re: EPICS build system DESTDIR support J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: RE: waveform arrays within SNL Al Honey
ANJ, 22 Jun 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
