While you can't do the filtering inside the IOC, if you don't mind using
an external tool to do that you can use the 'dbl' command to display all
your records (or all those of a specific record type) along with a
selection of their field values, so the command
dbl "ai", "SEVR STAT"
will print the record name and SEVR and STAT field values for all ai
records in the IOC. Use "" or "*" to request all record types. I would
redirect the output of this command to a file and grep through that file
at my leisure:
dbl "*", "SEVR STAT" > all-serv-stat.txt
I think this might even have worked with 3.13, but I'm not certain about
that (the "*" might not).
- Andrew
On 06/12/2017 03:46 PM, Matt Rippa wrote:
> We have some IOC's on 3.14.12.4 with several thousand records.
> Is there an easy way to get a severity report for any record where
> SEVR!=NO_ALARM ?
> I ask, because we're moving these systems from 3.13.x. We notice some
> non-existing input records now cause SEVR=INVALID and record processing
> is halted. This is a great new feature, btw.
> Thank you,
> -Matt
- Re: IOC Severity Report Matt Rippa
- IOC Severity Report Matt Rippa
Re: saving samples Andrew Johnson
Re: saving samples Miguel Bordalo
<2017>
Re: IOC Severity Report Dirk Zimoch
<2017>
