Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: RE: makeBaseApp.pl Compilation error on Windows x64
To: 'Saeed Haghtalab' <saeeed3715@gmail.com>, "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Wed, 7 Jun 2017 22:44:55 +0000
Hi Saeed,
I just tried what you did and it worked for me:
Windows 7 x64
Visual Studio 2015
ActiveState Perl 5.14.2
GNU Make 4.1
It works OK for me, the output is appended.
In your case the compiler is complaining that it cannot find xxxRecord.c.  Does that file indeed exist in the src/ directory?  This is your compile command that is failing:
cl                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32
-I../../../include -IC:/epics/base-3.15.5/include/compiler/msvc -IC:/epics/base-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include        -c ../xxxRecord.c
This is mine that is working:
-I../../../include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        -c ../xxxRecord.c
They look identical to me.
However, after the cl command you get this output, presumably from make:
process_begin: CreateProcess(NULL, cl -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL
-DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../.
./../include/os/WIN32 -I../../../include -IC:/epics/base-3.15.5/include/compiler/msvc -IC:/epics/base-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include –c ../xxxRecord.c, ...) failed.
make (e=2): The system cannot find the file specified.
I am not sure what file it is complaining that it cannot fine.  I don't see the "process_begin" message at all.
My complete output:
J:\epics\devel\example>H:\epics\base-3.15.5\bin\windows-x64-static\makebaseapp.pl -i -t example test
The following target architectures are available in base:
    linux-x86_64
    linux-x86
    vxWorks-ppc32
    windows-x64
    linux-x86_64-gcc42
    windows-x64-static
    win32-x86-static
    win32-x86
    linux-x86-rhel6
    windows-x64-static-vs2015
What architecture do you want to use? windows-x64
The following applications are available:
    test
What application should the IOC(s) boot?
The default uses the IOC's name, even if not listed above.
Application name?
J:\epics\devel\example>make
make -C ./configure install
make[1]: Entering directory 'J:/epics/devel/example/configure'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 install
make[2]: Entering directory 'J:/epics/devel/example/configure/O.windows-x64'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/convertRelease.pl checkRelease
make[2]: Leaving directory 'J:/epics/devel/example/configure/O.windows-x64'
make[1]: Leaving directory 'J:/epics/devel/example/configure'
make -C ./testApp install
make[1]: Entering directory 'J:/epics/devel/example/testApp'
make -C ./src install
make[2]: Entering directory 'J:/epics/devel/example/testApp/src'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../..
make -C O.windows-x64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'J:/epics/devel/example/testApp/src/O.windows-x64'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../../../dbd -IH:/epics/base-3.15.5/dbd -o xxxRecord.h ../xxxRecord.dbd
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/mkmf.pl  -m initTrace.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../includ
e -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        initTrace.obj ../initTrace.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/mkmf.pl  -m testHello.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../includ
e -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        testHello.obj ../testHello.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/mkmf.pl  -m dbSubExample.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../inc
lude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        dbSubExample.obj ../dbSubExample.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/mkmf.pl  -m devXxxSoft.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../inclu
de -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        devXxxSoft.obj ../devXxxSoft.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/mkmf.pl  -m xxxRecord.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../includ
e -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        xxxRecord.obj ../xxxRecord.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/mkmf.pl  -m testMain.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
-IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        testMain.obj ../testMain.cpp
"Creating dbd file test.dbd"
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -IH:/epics/base-3.15.5/dbd -o test.dbd base.dbd xxxSupport.dbd dbSubExample.dbd
testHello.dbd initTrace.dbd
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -IH:/epics/base-3.15.5/dbd    -o test_registerRecordDeviceDrive
r.cpp ../O.Common/test.dbd test_registerRecordDeviceDriver J:/epics/devel/example
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/mkmf.pl  -m test_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/W
IN32 -I../../../include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        test_registerRecordDeviceDriver.o
bj test_registerRecordDeviceDriver.cpp
"Installing dbd file ../../../dbd/xxxSupport.dbd"
mkdir ../../../dbd
"Installing created dbd file ../../../dbd/test.dbd"
"Installing dbd file ../../../dbd/xxxRecord.dbd"
"Installing generated generic include file ../../../include/xxxRecord.h"
mkdir ../../../include
cl                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common
-I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -
xxxRecord.c
../xxxRecord.c(211): warning C4244: '=': conversion from 'epicsFloat64' to 'float', possible loss of data
IH:/epics/base-3.15.5/include        -c ../devXxxSoft.c
devXxxSoft.c
IH:/epics/base-3.15.5/include        -c ../dbSubExample.c
dbSubExample.c
IH:/epics/base-3.15.5/include        -c ../testHello.c
testHello.c
IH:/epics/base-3.15.5/include        -c ../initTrace.c
initTrace.c
link -nologo /subsystem:windows /dll -LTCG -incremental:no -opt:ref -release  /MACHINE:X64      -out:testSupport.dll -implib:testSupport.lib        xxxRecord.obj devXxxSoft.obj dbS
ubExample.obj testHello.obj initTrace.obj      H:/epics/base-3.15.5/lib/windows-x64/dbRecStd.lib  H:/epics/base-3.15.5/lib/windows-x64/dbCore.lib  H:/epics/base-3.15.5/lib/windows-
x64/ca.lib  H:/epics/base-3.15.5/lib/windows-x64/Com.lib
   Creating library testSupport.lib and object testSupport.exp
Generating code
Finished generating code
"Installing shared library ../../../bin/windows-x64/testSupport.dll"
mkdir ../../../bin
mkdir ../../../bin/windows-x64
"Installing library ../../../lib/windows-x64/testSupport.lib"
mkdir ../../../lib
mkdir ../../../lib/windows-x64
cl -EHsc -GR                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344        -MD -DEPICS_BUILD_DLL -DEPICS_CA
LL_DLL -TP  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/b
ase-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        -c test_registerRecordDeviceDriver.cpp
ase-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        -c ../testMain.cpp
testMain.cpp
link -nologo  -LTCG -incremental:no -opt:ref -release  /MACHINE:X64              -out:test.exe       test_registerRecordDeviceDriver.obj testMain.obj     ../../../lib/windows-x64/t
estSupport.lib  H:/epics/base-3.15.5/lib/windows-x64/dbRecStd.lib  H:/epics/base-3.15.5/lib/windows-x64/dbCore.lib  H:/epics/base-3.15.5/lib/windows-x64/ca.lib  H:/epics/base-3.15.
Generating code
"Installing created executable ../../../bin/windows-x64/test.exe"
make[3]: Leaving directory 'J:/epics/devel/example/testApp/src/O.windows-x64'
make[2]: Leaving directory 'J:/epics/devel/example/testApp/src'
make -C ./Db install
make[2]: Entering directory 'J:/epics/devel/example/testApp/Db'
make[3]: Entering directory 'J:/epics/devel/example/testApp/Db/O.windows-x64'
"Installing ../../../db/dbExample1.db"
mkdir ../../../db
"Installing ../../../db/dbExample2.db"
"Installing ../../../db/dbSubExample.db"
"Installing substitution file ../../../db/user.substitutions"
make[3]: Leaving directory 'J:/epics/devel/example/testApp/Db/O.windows-x64'
make[2]: Leaving directory 'J:/epics/devel/example/testApp/Db'
make[1]: Leaving directory 'J:/epics/devel/example/testApp'
make -C ./iocBoot install
make[1]: Entering directory 'J:/epics/devel/example/iocBoot'
make -C ./ioctest install
make[2]: Entering directory 'J:/epics/devel/example/iocBoot/ioctest'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/convertRelease.pl -t J:/epics/devel/example envPaths
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/convertRelease.pl -a windows-x64 -t J:/epics/devel/example dllPath.bat
make[2]: Leaving directory 'J:/epics/devel/example/iocBoot/ioctest'
make[1]: Leaving directory 'J:/epics/devel/example/iocBoot'
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Saeed Haghtalab
Sent: Wednesday, June 07, 2017 4:11 PM
To: tech-talk@aps.anl.gov
Subject: makeBaseApp.pl Compilation error on Windows x64
Hi all,
I'm trying to build a template application using makeBaseApp.pl on windows but It fails. The system is:
Windows 8.1 x64
Visual Studio 2015
Strawberry Perl 5.26.0.1
GNU Make 4.1
First I built EPICS base-3.15.5 on windows and it built successfully without error.
I create template application as well but when I want to build this, I see the following error:
C:\Users\Saeed3715\Desktop\myApp>makeBaseApp.pl -t example test
C:\Users\Saeed3715\Desktop\myApp>makeBaseApp.pl -i -t example test
Using target architecture windows-x64 (only one available)
    test
Application name?
C:\Users\Saeed3715\Desktop\myApp>make.exe
make.exe -C ./configure install
make.exe[1]: Entering directory 'C:/Users/Saeed3715/Desktop/myApp/configure'
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/makeMakefile.pl O.windows-x64 ../
make.exe -C O.windows-x64 -f ../Makefile TOP=../.. \
make.exe[2]: Entering directory 'C:/Users/Saeed3715/Desktop/myApp/configure/O.wi
ndows-x64'
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/convertRelease.pl checkRelease
make.exe[2]: Leaving directory 'C:/Users/Saeed3715/Desktop/myApp/configure/O.win
dows-x64'
make.exe[1]: Leaving directory 'C:/Users/Saeed3715/Desktop/myApp/configure'
make.exe -C ./testApp install
make.exe[1]: Entering directory 'C:/Users/Saeed3715/Desktop/myApp/testApp'
make.exe -C ./src install
make.exe[2]: Entering directory 'C:/Users/Saeed3715/Desktop/myApp/testApp/src'
make.exe -C O.windows-x64 -f ../Makefile TOP=../../.. \
make.exe[3]: Entering directory 'C:/Users/Saeed3715/Desktop/myApp/testApp/src/O.
windows-x64'
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/dbdToRecordtypeH.pl   -I. -I.. -I
../O.Common -I../../../dbd -IC:/epics/base-3.15.5/dbd -o xxxRecord.h ../xxxRecor
d.dbd
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/mkmf.pl  -m initTrace.d -I. -I../
se-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include        initTrace.obj .
./initTrace.c
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/mkmf.pl  -m testHello.d -I. -I../
se-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include        testHello.obj .
./testHello.c
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/mkmf.pl  -m dbSubExample.d -I. -I
/base-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include        dbSubExample
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/mkmf.pl  -m devXxxSoft.d -I. -I..
ase-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include        devXxxSoft.obj
 ../devXxxSoft.c
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/mkmf.pl  -m xxxRecord.d -I. -I../
se-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include        xxxRecord.obj .
./xxxRecord.c
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/mkmf.pl  -m testMain.d -I. -I../O
e-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include        testMain.obj ../
testMain.cpp
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/dbdExpand.pl   -I. -I.. -I../O.Co
mmon -I../../../dbd -IC:/epics/base-3.15.5/dbd -o test.dbd base.dbd xxxSupport.d
bd dbSubExample.dbd testHello.dbd initTrace.dbd
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/registerRecordDeviceDriver.pl   -
I. -I.. -I../O.Common -I../../../dbd -IC:/epics/base-3.15.5/dbd    -o test_regis
terRecordDeviceDriver.cpp ../O.Common/test.dbd test_registerRecordDeviceDriver C
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/mkmf.pl  -m test_registerRecordDe
./../../include/os/WIN32 -I../../../include -IC:/epics/base-3.15.5/include/compi
       test_registerRecordDeviceDriver.obj test_registerRecordDeviceDriver.cpp
mkdir ../../../dbd
../xxxRecord.c
C:/epics/base-3.15.5/configure/RULES_BUILD:229: recipe for target 'xxxRecord.obj
' failed
make.exe[3]: *** [xxxRecord.obj] Error 2
make.exe[3]: Leaving directory 'C:/Users/Saeed3715/Desktop/myApp/testApp/src/O.w
indows-x64'
C:/epics/base-3.15.5/configure/RULES_ARCHS:58: recipe for target 'install.window
s-x64' failed
make.exe[2]: *** [install.windows-x64] Error 2
make.exe[2]: Leaving directory 'C:/Users/Saeed3715/Desktop/myApp/testApp/src'
C:/epics/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'src.install' fa
iled
make.exe[1]: *** [src.install] Error 2
make.exe[1]: Leaving directory 'C:/Users/Saeed3715/Desktop/myApp/testApp'
C:/epics/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'testApp.install
' failed
make.exe: *** [testApp.install] Error 2
does anyone know what is going on here?
Best
Saeed,
RE: makeBaseApp.pl Compilation error on Windows x64 freddie.akeroyd
makeBaseApp.pl Compilation error on Windows x64 Saeed Haghtalab
Prev: makeBaseApp.pl Compilation error on Windows x64 Saeed Haghtalab
Next: RE: makeBaseApp.pl Compilation error on Windows x64 freddie.akeroyd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
ANJ, 07 Jun 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
