1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: double crystal monochromator
To: 梁雅翔 <[email protected]>
Date: Wed, 7 Jun 2017 14:07:14 +0000
Hi Liang,
I don't understand your geometry well enough to know if kohzuSeqCtl will work.  For geometry 2, kohzuSeqCtl expects a Z motion, so the beam doesn't walk off the crystal face as theta decreases.  If you don't have a Z motion, you might be able to run in "Freeze Z" mode.
kohzuSeqCtl only controls the motors that must change as theta changes.  The other motions in the diagram (chi, theta2, x, y, and x2) are not controlled by kohzuSeqCtl.  They are controlled by motor records only.
GEOM selects between geometry 1 and geometry 2.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Sent: Wednesday, June 7, 2017 7:38:51 AM
To: Mooney, Tim M.
Cc: tech-talk
Subject: double crystal monochromator
Hi Mooney,
   I have some more question about the optics.
   We are using the double crystal monochromator( geometry2 ).
   I read your Instructions:http://www.aps.anl.gov/bcda/synApps/optics/opticsDocs.html
   The difference between the kohzu2Graphic.opi and ours was that, we just have four motors: one for No.2 crystal pitch, one for No.2 crystal raw, one for No.2 crystal move vertically (to adjust the height of lights), and one for bragg angle.
   When I set the st.cmd, I found that only "M_THETA, M_Y, M_Z,GEOM" could be set. I think these were different from our monochromator. I think we should set the mCHI2. And what was the GEOM means?
  Could you give me some suggestion?
Liang yx
double crystal monochromator 梁雅翔
Prev: Re: Questions about Java channel access client Ralph Lange
Next: Arbitrary limit on timeouts? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: double crystal monochromator 梁雅翔
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
