1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Questions about Java channel access client
To: [email protected]
Date: Wed, 7 Jun 2017 16:55:09 +0800 (GMT+08:00)
Dear all,
We need to develop the facility status web UI using Java for CSNS, the web UI will get data from live PVs, and we are now considering which Java channel access client library to use.
On the EPICS official website, the following ones are mentioned.
CAJ: Pure Java Channel Access Client (SF)
JCA: Channel Access client for Java using JNI (SF) (original at APS/BCDA)
CA: Another pure Java Channel Access client implementation (Github)
JCAE: Java Channel Access Extensions library (Github)
So my questions are as follows:
1. Are JCA and CAJ already obsolete? I ask because most documentations for them do not seem to be available anymore. Also, they are not moved to github like other active maintained projects.
2. Are CA and JCAE the replacement or improvement of JCA/CAJ?
3. For CA and JCAE, which one will you recommend?
Lin
RE: Questions about Java channel access client Mark Rivers
Re: Questions about Java channel access client Ralph Lange
Prev: epicsQt release 3.4.3 - at GitHub. Andrew C. Starritt
Next: RE: Questions about Java channel access client Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
