1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Channel Access client sees only partial update.
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 6 Jun 2017 22:14:08 +0200
Hello Mark,
I'am using asyn 4.26. / Epics 3.15.5.
There is only the main IOC thread copying source data to the block
buffer in a simple loop:
  size_t dataSize = BlockSize - headerSize;
  auto source = SourceData.data();
  auto dest = DataBlock.data();
  do {
      // prepare block header
      Blockheader.dataSizeInBlock = (sourceBytes > dataSize) ? dataSize
: sourceBytes ;
      // join header with data
      memcpy(dest, &Blockheader, sizeof(Blockheader));
      memcpy(dest + headerSize, source, Blockheader.dataSizeInBlock);
      // send away
      doCallbacksInt8Array(dest , headerSize +
Blockheader.dataSizeInBlock, Data, 0);
      printf("Block: %d DataSize: %d\n", Blockheader.blockNr,
      source += Blockheader.dataSizeInBlock;
      sourceBytes -= Blockheader.dataSizeInBlock;
      Blockheader.blockNr++;
  } while(sourceBytes);
This loop is between lock() and unlock().
Following is first the output from the subscribed channel access client
and after that the output of the IOC. There is a second process variable
subscribed that is updated once per main loop in the IOC called 'Image'
here. For this run the average data size is rather small so that it
splits in ~4 small blocks.
A longer output from the channel access client:
Block 493 Datasize 200272
Block 494 Datasize 204160
got Image
got Image
Block 498 Datasize 200272
got Image
Block 502 Datasize 198224
got Image
Block 506 Datasize 200272
got Image
Block 510 Datasize 198224
got Image
Block 511 Datasize 204160
got Image
Block 515 Datasize 200272
got Image
Block 519 Datasize 198224
got Image
Block 523 Datasize 198224
got Image
Block 527 Datasize 202320
got Image
Block 528 Datasize 202112
got Image
Block 532 Datasize 202320
got Image
Block 536 Datasize 194128
got Image
Block 540 Datasize 200272
got Image
Block 544 Datasize 200272
got Image
Block 545 Datasize 204160
got Image
Block 549 Datasize 200272
Block 550 Datasize 262112
got Image
Block 553 Datasize 196176
got Image
Block 557 Datasize 200272
got Image
Block 561 Datasize 200272
got Image
Block 562 Datasize 204160
got Image
Block 566 Datasize 200272
got Image
Block 570 Datasize 196176
got Image
Block 574 Datasize 200272
got Image
Block 578 Datasize 200272
got Image
Block 579 Datasize 204160
got Image
Block 583 Datasize 200272
got Image
Block 587 Datasize 196176
got Image
Block 591 Datasize 200272
got Image
Block 595 Datasize 202320
Block 596 Datasize 204160
IOC driver output at the same run:
Block: 498 DataSize: 200272
Reason to call CBF: measurement complete.
Block: 499 DataSize: 262112
Block: 500 DataSize: 262112
Block: 501 DataSize: 262112
Block: 502 DataSize: 198224
Block: 503 DataSize: 262112
Block: 504 DataSize: 262112
Block: 505 DataSize: 262112
Block: 506 DataSize: 200272
Block: 507 DataSize: 262112
Block: 508 DataSize: 262112
Block: 509 DataSize: 262112
Block: 510 DataSize: 198224
Block: 511 DataSize: 204160
Block: 512 DataSize: 262112
Block: 513 DataSize: 262112
Block: 514 DataSize: 262112
Block: 515 DataSize: 200272
Block: 516 DataSize: 262112
Block: 517 DataSize: 262112
Block: 518 DataSize: 262112
Block: 519 DataSize: 198224
Block: 520 DataSize: 262112
Block: 521 DataSize: 262112
Block: 522 DataSize: 262112
Block: 523 DataSize: 198224
Block: 524 DataSize: 262112
Block: 525 DataSize: 262112
Block: 526 DataSize: 262112
Block: 527 DataSize: 202320
Block: 528 DataSize: 202112
Block: 529 DataSize: 262112
Block: 530 DataSize: 262112
Block: 531 DataSize: 262112
Block: 532 DataSize: 202320
Block: 533 DataSize: 262112
Block: 534 DataSize: 262112
Block: 535 DataSize: 262112
Block: 536 DataSize: 194128
Block: 537 DataSize: 262112
Block: 538 DataSize: 262112
Block: 539 DataSize: 262112
Block: 540 DataSize: 200272
Block: 541 DataSize: 262112
Block: 542 DataSize: 262112
Block: 543 DataSize: 262112
Block: 544 DataSize: 200272
Block: 545 DataSize: 204160
Block: 546 DataSize: 262112
Block: 547 DataSize: 262112
Block: 548 DataSize: 262112
Block: 549 DataSize: 200272
Block: 550 DataSize: 262112
Block: 551 DataSize: 262112
Block: 552 DataSize: 262112
Block: 553 DataSize: 196176
Block: 554 DataSize: 262112
Block: 555 DataSize: 262112
Block: 556 DataSize: 262112
Block: 557 DataSize: 200272
Block: 558 DataSize: 262112
Block: 559 DataSize: 262112
Block: 560 DataSize: 262112
Block: 561 DataSize: 200272
Block: 562 DataSize: 204160
Block: 563 DataSize: 262112
Block: 564 DataSize: 262112
Block: 565 DataSize: 262112
Block: 566 DataSize: 200272
Block: 567 DataSize: 262112
Block: 568 DataSize: 262112
Block: 569 DataSize: 262112
Block: 570 DataSize: 196176
Block: 571 DataSize: 262112
Block: 572 DataSize: 262112
Block: 573 DataSize: 262112
Block: 574 DataSize: 200272
Block: 575 DataSize: 262112
Block: 576 DataSize: 262112
Block: 577 DataSize: 262112
Block: 578 DataSize: 200272
Block: 579 DataSize: 204160
Block: 580 DataSize: 262112
Block: 581 DataSize: 262112
Block: 582 DataSize: 262112
Block: 583 DataSize: 200272
Block: 584 DataSize: 262112
Block: 585 DataSize: 262112
Block: 586 DataSize: 262112
Block: 587 DataSize: 196176
Block: 588 DataSize: 262112
Block: 589 DataSize: 262112
Block: 590 DataSize: 262112
Block: 591 DataSize: 200272
Block: 592 DataSize: 262112
Block: 593 DataSize: 262112
Block: 594 DataSize: 262112
Block: 595 DataSize: 202320
Block: 596 DataSize: 204160
I hope that helps.
Best regards,
Michael
On 06.06.2017 21:38, Mark Rivers wrote:
> Hi Michael,
> What version of asyn are you using?
> Can you send a longer sequence of blocks received with and without the info tag?
>> A rough guess of me is that the copy to the ring buffer is late and the
>> source was already updated with the next block?
> The copy to the ring buffer in done in your driver's thread that is calling doCallbacksInt8Array(blockPtr , block_size, Data, 0).  There is no way it can be "late".
> The only way I can see for the data to be overwritten is if your driver has another thread which is modifying the data in blockPtr while doCallbacksInt8Array() is executing.  If so you need to use a mutex to make sure you don't change the data in blockPtr before doCallbacksInt8Array has returned.
> In areaDetector normally the data is copied into an NDArray object that is allocated from the NDArrayPool.  The driver calls doCallbacksGenericPointer() to pass the NDArray to the plugins.  The NDPluginStdArrays plugin is what would actually call doCallbacksInt8Array.  It then decrements the reference count on the NDArray, returning it to the NDArrayPool if this was the last reference.  This prevents overwriting buffers if you have another thread getting the data from the device because it would always allocate a new NDArray.
>> Is there a way to block execution in the IOC to be sure that the data is in the Channel Access output buffer?
> You don't need to wait for it to be in the Channel Access buffer, that is the point of the ring buffers.  The waveform record device support can buffer multiple arrays in the ring buffer.  You just need to make sure that your driver does not modify the data pointed to by blockPtr until doCallbacksInt8Array() has returned.
> Mark
> -----Original Message-----
> From: Michael Huth [mailto:[email protected]]
> Sent: Tuesday, June 06, 2017 2:14 PM
> To: Mark Rivers; [email protected]
> Hello Mark,
> with the line added to the database file the behavior is not much different,
> just that I get now sometimes really multiple blocks per IOC task loop,
> however with block IDs like this:
> Block 1037
> Block 1038
> Block 1041
> Block 1041
> where e.g. a block with the 1041 data is sent twice. The ID number is
> part of the blocks data.
> The HDF5 swmr is actually already implemented in the CA client. It is
> not planned to use HDF5 writing as part of the IOC driver.
> Best regards,
> Michael
> On 06.06.2017 20:28, Mark Rivers wrote:
>> Hi Michael,
>> By default the devAsynInt8Array callback does not buffer the array it receives, it copies it directly into the waveform record.  If your driver callbacks are happening faster than the record processing and Channel Access transfer to the client then what you are seeing is expected.
>> devAsynInt8Array can optionally use a ring-buffer to buffer the arrays passed to the callback function.  This should eliminate the problem you are seeing.  The ring buffer is disabled by default, but you can enable it by adding this line to your waveform record database file:
>> info(asyn:FIFO, "20")
>> where 20 is the maximum number of blocks you want to be able to buffer.
>> This is documented here (search for "Buffering of Driver Callbacks"):
>> http://www.aps.anl.gov/epics/modules/soft/asyn/R4-31/asynDriver.html
>> How large is the data set you are trying to transfer?  Are you breaking it into blocks because of its size, or is your source actually delivering it in sub-blocks?
>> Mark
>> From: [email protected] [mailto:[email protected]] On Behalf Of Michael Huth
>> Sent: Tuesday, June 06, 2017 1:15 PM
>> To: [email protected]
>> Subject: Channel Access client sees only partial update.
>> Hello,
>> I'am quite new to Epics and ran into an issue where I could use a hint
>> how to solve it:
>> I have an IOC driver based on the area detector driver that should be
>> extended for the transfer of a large data set from another source.
>> So I setup a Record for it like this:
>> record(waveform, "$(P)$(R)Data")
>>     field(PINI, "0")
>>     field(DTYP, "asynInt8ArrayIn")
>>     field(INP,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))DATA")
>>     field(FTVL, "CHAR")
>>     field(NELM, "$(SIZE_DATA_BLOCK)")
>>     field(SCAN, "I/O Intr")
>> In the main thread of the IOC I split the large data set into smaller
>> blocks and have a loop that calls
>> doCallbacksInt8Array(blockPtr , block_size, Data, 0);
>> for each block to transfer the blocks to the data base.
>> In a second process a channel access client is subscribed with
>> ca_create_subscription to 'DATA'.
>> The issue is that the client receives only the last block from each loop
>> of the IOC driver thread.
>> I guess I have to wait somehow until the database processing has
>> finished after each block?!?
>> Best regards,
>> Michael Huth
() byte physics
    Dr. Michael Huth
    Software-Developer
Company CEO: Thomas Braun
Address:     Schwarzastraße 9, 12055 Berlin, Germany
Web:         www.byte-physics.de
Telephone:   +49 (0)30/52 68 23 22
Fax:         +49 (0)30/52 68 43 26
USt-IdNr:    DE276717536
RE: Channel Access client sees only partial update. Mark Rivers
Channel Access client sees only partial update. Michael Huth
Re: Channel Access client sees only partial update. Michael Huth
Prev: RE: Channel Access client sees only partial update. Mark Rivers
Next: RE: Channel Access client sees only partial update. Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
