Hello,
I'am quite new to Epics and ran into an issue where I could use a hint
how to solve it:
I have an IOC driver based on the area detector driver that should be
extended for the transfer of a large data set from another source.
So I setup a Record for it like this:
record(waveform, "$(P)$(R)Data")
field(PINI, "0")
field(DTYP, "asynInt8ArrayIn")
field(INP, "@asyn($(PORT),$(ADDR),$(TIMEOUT))DATA")
field(FTVL, "CHAR")
field(NELM, "$(SIZE_DATA_BLOCK)")
field(SCAN, "I/O Intr")
In the main thread of the IOC I split the large data set into smaller
blocks and have a loop that calls
doCallbacksInt8Array(blockPtr , block_size, Data, 0);
for each block to transfer the blocks to the data base.
In a second process a channel access client is subscribed with
ca_create_subscription to 'DATA'.
The issue is that the client receives only the last block from each loop
of the IOC driver thread.
I guess I have to wait somehow until the database processing has
finished after each block?!?
Best regards,
Michael Huth
() byte physics
Dr. Michael Huth
Software-Developer
Company CEO: Thomas Braun
Address: Schwarzastraße 9, 12055 Berlin, Germany
Web: www.byte-physics.de
Telephone: +49 (0)30/52 68 23 22
Fax: +49 (0)30/52 68 43 26
USt-IdNr: DE276717536
- RE: Channel Access client sees only partial update. Mark Rivers
Re: How to deal with LINK_ALARM Ralph Lange
<2017>
<2017>
