Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: RE: stream enum
To: l123173 <l123173@163.com>, tech-talk <tech-talk@aps.anl.gov>
Date: Mon, 5 Jun 2017 13:44:35 +0000
You should be able to change the record to ai or longin.
What is an example string from the device that you are trying to parse?
From: tech-talk-bounces@aps.anl.gov [tech-talk-bounces@aps.anl.gov] on behalf of l123173 [l123173@163.com]
Sent: Monday, June 05, 2017 8:28 AM
To: tech-talk
Subject: stream enum
Hi all,
   I met some little question about stream.
   After I sent command, I received a sequence of character through stream.
   The pv type was stringin and the value of the pv was 1(string) or 0(string).
   My question was that, I need the pv value was natural number( 0 or 1 ), not string type.
   I have tried to change the stringin to ai, some error came out. Then I think I could use the enum, but I could not know the usage though I tried.
   Could someone give some help.
Li xing
My db and proto file.
record(stringin, "$(P)$(R)STAT")
    field(DESC, "test")
    field(DTYP, "stream")
    field(INP,  "@devplc2.proto STAT $(PORT) $(A)")
STAT{
    out "\x0500FFBR2Y0000402F";
     in "\x02%*4s%c%*c%*c%*c%*c%*c%*c%*c%*c%*c%*s";
stream enum l123173
Prev: stream enum l123173
Next: Re: EPICS Base-3.16.1 Released J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: Re: stream enum Dirk Zimoch
ANJ, 08 Jun 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
