1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Use default value if CA link error
To: Luca Cavalli <[email protected]>
Date: Mon, 5 Jun 2017 12:59:50 +0200 (CEST)
Hi Luca,
if I don't make a mistake, you can use the DOL/OMSL fields in order to
read the desired value from your CA link using the stringout record.
Hope this helps,
- Maurizio
On Jun 05, 2017 12:41 PM, Luca Cavalli <[email protected]> wrote:
> Hi Maurizio,
> this seems a much better approach.
> I have a stringin record with INP field getting PV from CA link, but
> it is missing IVOA/IVOV fields (available in stringout).
> I can switch to stringout but how can I retrieve my PV value via CA
> link?
> Thanks again,
> Luca
> On Mon, 2017-06-05 at 12:20 +0200, Maurizio Montis wrote:
> Dear Luca,
> the IVOA/IVOV mechanism should be the correct way to solve your
> problem,
> no need of external modules.
> * IVOA (Invalid Output Action) selects what to do in case the record
> gets INVALID.
> * IVOV (Invalid Output Value) is a CONSTANT holding the value that
> should be used when the record is INVALID.
> The connection going down should always put the record in LINK
> INVALID.
> I had a similar situation and Ralph Lange pointed me to this solution
> (thanks a lot Ralph!).
> Cheers,
> - Maurizio
> On Jun 05, 2017 11:52 AM, Luca Cavalli
> <[email protected]<mailto:[email protected]>> wrote:
> Dear all,
> I have a string input record which value is retrieved via CA link.
> When remote
> PV is not available (e.g. missing IOC) I would like to set "EMPTY" as
> string
> input value.
> My idea is to use scalcout record from synApps with CA link connected
> to INAA
> and IAAV connected to INPA, defining the output by checking INPA value
> and
> selecting INAA (Ext PV OK) or "EMPTY" constant (Ext PN NC).
> Before adding scalcout record to my IOC I would like to know if this
> is a good
> approach. Is there a simpler solution?
> Thanks,
> Luca
> ~~ Maurizio Montis - Control System Engineer ~~
>    office: +39 0498068558
>    mobile: +39 3408428089
> mail: [email protected]<mailto:[email protected]>
>    skype: maurizio_montis
> Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di
> Legnaro
>    V.le dell'Universita', 2
>    35020 LEGNARO (PD) - ITALY
> ________________________________
> << Le informazioni contenute in questo messaggio di posta elettronica
> e relativi allegati sono riservate e confidenziali e ne è vietata la
> diffusione in qualunque modo eseguita. Qualora Lei non fosse la
> persona a cui il presente messaggio è destinato, La invitiamo ad
> eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini
> del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003
> n.196, sulla tutela dei dati personali >>
> << This e-mail is confidential and may well also be legally
> privileged. If you have received it in error, you are on notice of its
> status. Please notify us immediately by reply e-mail and then delete
> this message from your system. Please do not copy it or use it for any
> purposes, or disclose its contents to any other person: to do so could
> be a breach of confidence. Thank you for your co-operation. Please
> contact our IT Helpdesk on +3902380481 or email [email protected] if you
> need assistance >>
Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
Re: Use default value if CA link error Luca Cavalli
Re: Use default value if CA link error Maurizio Montis
Prev: Re: Use default value if CA link error Luca Cavalli
Next: Re: Use default value if CA link error Luca Cavalli
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
