Dear Luca,
the IVOA/IVOV mechanism should be the correct way to solve your problem,
no need of external modules.
* IVOA (Invalid Output Action) selects what to do in case the record
gets INVALID.
* IVOV (Invalid Output Value) is a CONSTANT holding the value that
should be used when the record is INVALID.
The connection going down should always put the record in LINK INVALID.
I had a similar situation and Ralph Lange pointed me to this solution
(thanks a lot Ralph!).
Cheers,
- Maurizio
On Jun 05, 2017 11:52 AM, Luca Cavalli <[email protected]> wrote:
> Dear all,
> I have a string input record which value is retrieved via CA link.
> When remote
> PV is not available (e.g. missing IOC) I would like to set "EMPTY" as
> string
> input value.
> My idea is to use scalcout record from synApps with CA link connected
> to INAA
> and IAAV connected to INPA, defining the output by checking INPA value
> and
> selecting INAA (Ext PV OK) or "EMPTY" constant (Ext PN NC).
> Before adding scalcout record to my IOC I would like to know if this
> is a good
> approach. Is there a simpler solution?
> Thanks,
> Luca
> ________________________________
> << Le informazioni contenute in questo messaggio di posta elettronica
> e relativi allegati sono riservate e confidenziali e ne è vietata la
> diffusione in qualunque modo eseguita. Qualora Lei non fosse la
> persona a cui il presente messaggio è destinato, La invitiamo ad
> eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini
> del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003
> n.196, sulla tutela dei dati personali >>
> << This e-mail is confidential and may well also be legally
> privileged. If you have received it in error, you are on notice of its
> status. Please notify us immediately by reply e-mail and then delete
> this message from your system. Please do not copy it or use it for any
> purposes, or disclose its contents to any other person: to do so could
> be a breach of confidence. Thank you for your co-operation. Please
> contact our IT Helpdesk on +3902380481 or email [email protected] if you
> need assistance >>
~~ Maurizio Montis - Control System Engineer ~~
office: +39 0498068558
mobile: +39 3408428089
mail: [email protected]
skype: maurizio_montis
Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
V.le dell'Universita', 2
35020 LEGNARO (PD) - ITALY
- Re: Use default value if CA link error Luca Cavalli
- Use default value if CA link error Luca Cavalli
<2017>
<2017>
