1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: seqChanShow oddities when running through procServ
To: "Southern, Tim" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 2 Jun 2017 18:04:25 +0000
Hi Tim,
I do not have that problem.  I have soft IOCs running under procServ and when I type seqChanShow the Enter key works fine to advance to the next channel.
I suspect something is set wrong with your procServ command?  We are invoking procsServ in a script as follows:
# Command definition
procserv = '/usr/local/bin/procServ --logstamp -n "%s_IOC" -L /home/epics/logs/%s.log %s %s'
# Invoke above command for each IOC
        pcmd = procserv % (iocname, iocname, port, cmd)
From: [email protected] [[email protected]] on behalf of Southern, Tim [[email protected]]
Sent: Friday, June 02, 2017 11:57 AM
To: [email protected]
Subject: seqChanShow oddities when running through procServ
I have found an issue with the sequencer command 'seqChanShow', when
logged into a softIoc via procServ telnet.
Running this command on a sequencer will output the first channel in the
sequencer as expected. For some reason, the terminal does not recognize
the linefeed command using the enter key to proceed to the next channel.
Instead, I discovered you have to use cntrl-j ?
The sequencer command works normally for a sequencer I run locally?
I am running softIocs on the following systems:
RHEL Linux kernel -  2.6.32-642.1.1.el6.i686
EPICS Version - R3.14.11
Sequencer Version - seq-2.2.3
Tim Southern
seqChanShow oddities when running through procServ Southern, Tim
Prev: RE: Any issues with Base-3.16.1-rc1? freddie.akeroyd
Next: Re: seqChanShow oddities when running through procServ Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: seqChanShow oddities when running through procServ Southern, Tim
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
