I have found an issue with the sequencer command 'seqChanShow', when
logged into a softIoc via procServ telnet.
Running this command on a sequencer will output the first channel in the
sequencer as expected. For some reason, the terminal does not recognize
the linefeed command using the enter key to proceed to the next channel.
Instead, I discovered you have to use cntrl-j ?
The sequencer command works normally for a sequencer I run locally?
I am running softIocs on the following systems:
RHEL Linux kernel - 2.6.32-642.1.1.el6.i686
EPICS Version - R3.14.11
Sequencer Version - seq-2.2.3
Tim Southern
- RE: seqChanShow oddities when running through procServ Mark Rivers
- Re: seqChanShow oddities when running through procServ Ralph Lange
Any issues with Base-3.16.1-rc1? Andrew Johnson
RE: Any issues with Base-3.16.1-rc1? freddie.akeroyd
<2017>
Re: Any issues with Base-3.16.1-rc1? Lang, Keenan C.
<2017>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
