Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: RE: epicsqt
To: Mark Rivers <rivers@cars.uchicago.edu>
Cc: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Mon, 29 May 2017 21:42:12 +0000
Hi Mark,
   I had to do a qmake in the framework directory, then make install. That populated the QE widgets in a place where designer could find them. I think the build script must be incomplete. I'll try again on a clean machine to see if I had some history which interfered.
Thanks for the tip :)
Pete.
From: tech-talk-bounces@aps.anl.gov [tech-talk-bounces@aps.anl.gov] on behalf of Siddons, David [siddons@bnl.gov]
Sent: Monday, May 29, 2017 4:55 PM
To: Mark Rivers
Cc: tech-talk@aps.anl.gov
Hi Mark,
  Good guess! I did "make install" and it moved a bunch of headers around, and the build went a lot further. I still have a couple of issues, so let me see how far I can get.
Pete.
Sent: Monday, May 29, 2017 4:19 PM
To: Siddons, David
It sounds like perhaps those files should have been installed somewhere, perhaps in /home/peter/epicsqt//include.  Was there perhaps a missing "make" step in /home/peter/epicsqt/trunk/framework.  Can you trying running make there?  Just a guess.
Sent: Monday, May 29, 2017 3:05 PM
To: Mark Rivers
Hi Mark,
  The two files not found are in:
/home/peter/epicsqt/trunk/framework/widgets/QEWidget/ContainerProfile.h
/home/peter/epicsqt/trunk/framework/common/QEFormMapper.h
They are not in the QEGuiApp/ directory at all.
Pete.
Sent: Monday, May 29, 2017 3:56 PM
To: Siddons, David
Hi Pete,
What directories are ContainerProfile.h and QEFormMapper.h located in?
The directories being searched with -I when building main.cpp are:
-I/usr/share/qt4/mkspecs/linux-g++
-I.
-I/usr/include/qt4/QtUiTools
-I/usr/include/qt4/QtDesigner
-I/usr/include/qt4/QtCore
-I/usr/include/qt4/QtNetwork
-I/usr/include/qt4/QtGui
-I/usr/include/qt4/QtXml
-I/usr/include/qt4/QtScript
-I/usr/include/qt4
-IO.linux-x86_64/uiQe
-Iinclude
-I/home/peter/epicsqt//include
-IO.linux-x86_64/moc
-IO.linux-x86_64/ui
It looks like the current default directory when it compiles main.cpp is /home/peter/epicsqt/trunk/applications/QEGuiApp.  So that is the location of ., include, and O.linux-x86_64.
Is ContainerProfile.h in one of those directories?
Sent: Monday, May 29, 2017 2:35 PM
To: Mark Rivers
Hi Mark,
  I started from scratch, by downloading the Application Makefile from the svn repository, as per the docs, and running make. It downloads all the code and starts a build. Eventually it stops here:
cd applications/QEGuiApp/ && make -f Makefile.linux-x86_64
make[2]: Entering directory '/home/peter/epicsqt/trunk/applications/QEGuiApp'
/usr/lib/x86_64-linux-gnu/qt4/bin/uic src/MainWindow.ui -o O.linux-x86_64/ui/ui_MainWindow.h
/usr/lib/x86_64-linux-gnu/qt4/bin/uic src/MessageLog.ui -o O.linux-x86_64/ui/ui_MessageLog.h
/usr/lib/x86_64-linux-gnu/qt4/bin/uic src/saveDialog.ui -o O.linux-x86_64/ui/ui_saveDialog.h
/usr/lib/x86_64-linux-gnu/qt4/bin/uic src/restoreDialog.ui -o O.linux-x86_64/ui/ui_restoreDialog.h
/usr/lib/x86_64-linux-gnu/qt4/bin/uic src/manageConfigDialog.ui -o O.linux-x86_64/ui/ui_manageConfigDialog.h
/usr/lib/x86_64-linux-gnu/qt4/bin/uic src/aboutDialog.ui -o O.linux-x86_64/ui/ui_aboutDialog.h
g++ -c -pipe -O2 -D_REENTRANT -Wall -W -DQT_NO_DEBUG -DQT_SCRIPT_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtUiTools -I/usr/include/qt4/QtDesigner -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtNetwork -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtXml -I/usr/include/qt4/QtScript -I/usr/include/qt4 -IO.linux-x86_64/ui -I. -Iinclude -I/home/peter/epicsqt//include -IO.linux-x86_64/moc -IO.linux-x86_64/ui -o O.linux-x86_64/obj/main.o src/main.cpp
g++ -c -pipe -O2 -D_REENTRANT -Wall -W -DQT_NO_DEBUG -DQT_SCRIPT_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtUiTools -I/usr/include/qt4/QtDesigner -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtNetwork -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtXml -I/usr/include/qt4/QtScript -I/usr/include/qt4 -IO.linux-x86_64/ui -I. -Iinclude -I/home/peter/epicsqt//include -IO.linux-x86_64/moc -IO.linux-x86_64/ui -o O.linux-x86_64/obj/MainWindow.o src/MainWindow.cpp
In file included from src/main.cpp:27:0:
include/QEGui.h:31:30: fatal error: ContainerProfile.h: No such file or directory
compilation terminated.
Makefile.linux-x86_64:332: recipe for target 'O.linux-x86_64/obj/main.o' failed
make[2]: *** [O.linux-x86_64/obj/main.o] Error 1
make[2]: *** Waiting for unfinished jobs....
In file included from src/MainWindow.cpp:145:0:
include/MainWindow.h:31:26: fatal error: QEFormMapper.h: No such file or directory
Makefile.linux-x86_64:339: recipe for target 'O.linux-x86_64/obj/MainWindow.o' failed
make[2]: *** [O.linux-x86_64/obj/MainWindow.o] Error 1
make[2]: Leaving directory '/home/peter/epicsqt/trunk/applications/QEGuiApp'
Makefile.linux-x86_64:81: recipe for target 'sub-applications-QEGuiApp-make_default-ordered' failed
make[1]: *** [sub-applications-QEGuiApp-make_default-ordered] Error 2
make[1]: Leaving directory '/home/peter/epicsqt/trunk'
makefile:111: recipe for target 'framework' failed
make: *** [framework] Error 2
The files it complains about do exist in the installed code.
Pete.
Sent: Monday, May 29, 2017 2:43 PM
To: Siddons, David
Subject: Re: epicsqt
Hi Pete,
Can you send the complete command that failed, and also the location of ContainerProfile.h? If it is in the distribution then there is probably a problem with -I in the compile command.
Sent from my iPhone
On May 29, 2017, at 11:47 AM, Siddons, David <siddons@bnl.gov<mailto:siddons@bnl.gov>> wrote:
I am trying to build epicsqt using the application makefile. The build stops while building MainWindow.cpp with two errors:
These files do exist in the distribution; why are they not found?
I am building with epics 3.15.5 on Ubuntu 16.04. Is there an environment variable which I missed?
Pete.
epicsqt Siddons, David
Re: epicsqt Mark Rivers
RE: epicsqt Siddons, David
RE: epicsqt Mark Rivers
Prev: RE: epicsqt Siddons, David
Next: Configuring multiple ports with variable port numbers for StreamDevice Jonathan Takahashi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
ANJ, 30 May 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
