1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: ADSimDetector
To: "Mark Rivers" <[email protected]>
Cc: [email protected]
Date: Fri, 26 May 2017 11:55:40 -0500
Mark –
Hypothetical question.
You have posted at various time ADSimDetector beanchmarks. Historical values from a PDF that I am looking at now being about 485 FPS for a 1024 x4 1024 image. If I increase this image dimensions  to 3078 by 4096, basically 12 times the data, the frame rate  drops by about the same factor of 12 down to 40 FPS or so (This is confirmed using one of your old AD1.9 windows prebuilts and playing with image sizes).  This FPS  value is pulled from at the very top level NDStdArray plugin, blocking, so frames are not dropped.
In AD3-0, This plugin is multi-thread enabled.  I’m assuming that if someone did not specify a value, 1 thread is allocated for this plugin and that more *might* make it handle bigger data or faster data.  I.e., 5 threads might make that original 1024 x 1024 image collect at . . . 2400+ FPS . . . and that larger image perhaps 200 FPS without dropping frames.
Or am I mistaken on how the AD3.0 threads work?
I have a newer model Xeon computer with 12 real cores, most of which are idle at any given moment, and was wondering which plugins may be worth committing cores to.
Me
RE: ADSimDetector Mark Rivers
Re: ADSimDetector Michael Davidsaver
Prev: Re: Force TCP/IP reconnect from Asyn/Streamdevice Paduan Donadio, Marcio
Next: RE: ADSimDetector Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: support for Thorlabs ODC001 D Peter Siddons
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
