Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Problem installing PyEpics
To: Alan Kastengren <akastengren@anl.gov>
Cc: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Tue, 23 May 2017 15:58:01 +0000
Hi Alan,
I’ve been beaten by the same problem today (again) and the solution on RHEL7 is to install readline-devel .rpm package. Hope it helps.
— Klemen
> On Jan 30, 2017, at 10:59 AM, Alan Kastengren <akastengren@anl.gov> wrote:
>    I am trying to get a development machine on Linux RHEL 7 configured so I can work on PyEpics scripting, and I am having some difficulties.  I have installed EPICS base 3.14.12.6 and set the PYEPICS_LIBCA, EPICS_BASE, and EPICS_HOST_ARCH environment variables.  I'm using the Anaconda Python distribution (version 2.7 of Python) on a local install on my machine (since it's a laptop and won't always have access to APSshare).  I installed PyEpics through conda (version 3.2.6), as described on the PyEpics website for installation instructions.  I can perform caput and caget from the Bash shell, so I believe EPICS itself is working correctly.
>    My problem is that if start an interactive Python session I can import epics and perform caput and caget, instantiate a PV object, etc just fine.  If I try to run the exact same commands from a script, I can still import epics without an error, but I get the error shown below whenever I first try to do either a caget or instantiate a PV object.  I've confirmed that the runtime is looking in the same location for the library file in both the interactive session and the script, and that both have the same sys.path (except for the local directory being on the path for the scripted version) and Python version.  I'm really at a loss.
> Traceback (most recent call last):
>  File "/home/akastengren/anaconda2/lib/python2.7/site-packages/epics/ca.py", line 215, in initialize_libca
>    libca = load_dll(dllname)
>  File "/home/akastengren/anaconda2/lib/python2.7/ctypes/__init__.py", line 440, in LoadLibrary
>    return self._dlltype(name)
>  File "/home/akastengren/anaconda2/lib/python2.7/ctypes/__init__.py", line 362, in __init__
>    self._handle = _dlopen(self._name, mode)
> OSError: /home/akastengren/anaconda2/bin/../lib/libreadline.so.6: undefined symbol: PC
>  File "/home/akastengren/Python/workspace/PyEpics_Scripting/Test_install.py", line 9, in <module>
>    print(epics.caget('7bmb1:m1.VAL'))
>  File "/home/akastengren/anaconda2/lib/python2.7/site-packages/epics/__init__.py", line 81, in caget
>    thispv = get_pv(pvname, connect=True)
>  File "/home/akastengren/anaconda2/lib/python2.7/site-packages/epics/pv.py", line 39, in get_pv
>    context = ca.current_context()
>  File "/home/akastengren/anaconda2/lib/python2.7/site-packages/epics/ca.py", line 362, in wrapper
>    initialize_libca()
>  File "/home/akastengren/anaconda2/lib/python2.7/site-packages/epics/ca.py", line 217, in initialize_libca
>    raise ChannelAccessException('loading Epics CA DLL failed: ' + str(exc))
> epics.ca.ChannelAccessException: loading Epics CA DLL failed: /home/akastengren/anaconda2/bin/../lib/libreadline.so.6: undefined symbol: PC
Re: Problem installing PyEpics Michael Davidsaver
Problem installing PyEpics Alan Kastengren
Prev: support for Thorlabs ODC001 D Peter Siddons
Next: Re: Problem installing PyEpics Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: Problem installing PyEpics Matt Newville
ANJ, 23 May 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
