Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Disabling a record from scanning during a program event
To: Iain Marcuson <Iain.Marcuson@sydorinstruments.com>, "tech-talk@aps.anl.gov >> EPICS Tech Talk" <tech-talk@aps.anl.gov>
Date: Mon, 22 May 2017 19:43:39 +0000
Hi Iain,
There is some information about the SDIS+DISV+DISA mechanism in the Record Reference Wiki at https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_dbCommon#Scan_Fields although it's not really the comprehensive tutorial you asked for.
HTH,
- Andrew
From: tech-talk-bounces@aps.anl.gov <tech-talk-bounces@aps.anl.gov> on behalf of Iain Marcuson <Iain.Marcuson@sydorinstruments.com>
Sent: Monday, May 22, 2017 10:59:24 AM
To: Michael Davidsaver; tech-talk@aps.anl.gov >>        EPICS Tech Talk
Subject: RE: Disabling a record from scanning during a program event
Mark sent me a suggestion of the same thing.  I am still curious about the binding however.  Is there a good tutorial on those?
Thank you,
Iain.
> -----Original Message-----
> From: Michael Davidsaver [mailto:mdavidsaver@gmail.com]
> Sent: Monday, May 22, 2017 11:58 AM
> To: Iain Marcuson <Iain.Marcuson@sydorinstruments.com>; tech-
> talk@aps.anl.gov >> EPICS Tech Talk <tech-talk@aps.anl.gov>
> On 05/22/2017 11:26 AM, Iain Marcuson wrote:
> > I have a setup that acquires an image from custom AreaDetector code for a
> custom camera.  The controller provides a command that returns the
> progress of an acquisition, since they can be quite long.  I have created a PV
> to query the progress of the acquisition, querying every 0.2 seconds.  I only
> want to scan when an acquisition is in progress.  I assume I would
> appropriately set the DISV and DISA fields of the progress PV.  However, I am
> lost at how I would set these variables from the acquisition code.  Is there an
> example or description of the bindings?
> You might be able to point the SDIS link at the Acquire record.  Use the CP
> link modifier.  The value read from SDIS is stored in DISA.  So setting DISV==0
> should disable the scan when Acquire==0.
Disabling a record from scanning during a program event Iain Marcuson
Re: Disabling a record from scanning during a program event Michael Davidsaver
RE: Disabling a record from scanning during a program event Iain Marcuson
Prev: RE: Disabling a record from scanning during a program event Iain Marcuson
Next: Force TCP/IP reconnect from Asyn/Streamdevice Christoph Schroeder
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: RE: Disabling a record from scanning during a program event Iain Marcuson
ANJ, 23 May 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
