Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Streamdevice waveform - binary data stream with no separator
To: "Paduan Donadio, Marcio" <marcio@slac.stanford.edu>
Cc: "Tech-talk@aps.anl.gov" <Tech-talk@aps.anl.gov>
Date: Thu, 18 May 2017 21:23:17 +0000
Yes, Stream reads NELM elements or stops when the input is exhausted, whatever happens first.
Dirk
Am 18.05.2017 um 21:33 schrieb Paduan Donadio, Marcio <marcio@slac.stanford.edu>:
Thank you, Iain.
How do you let stream device know that you want exactly 140 numbers? Only setting NELM is sufficient?
Best regards,
Márcio Paduan Donadio
Software Engineer - TID-AIR-ACS - SLAC
De: Iain Marcuson <Iain.Marcuson@sydorinstruments.com>
Enviado: quinta-feira, 18 de maio de 2017 12:19
Para: Paduan Donadio, Marcio
Assunto: RE: Streamdevice waveform - binary data stream with no separator
I have used something similar.  You would use the %r format specifier, in I believe something like:
In “%2.2r”
You may need to add the “#” flag to account for endianness.  For this you would set the separator to be blank.
Iain.
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Paduan Donadio, Marcio
Sent: Thursday, May 18, 2017 1:25 PM
To: EPICS tech talk <Tech-talk@aps.anl.gov>
Subject: Streamdevice waveform - binary data stream with no separator
Good morning to all!
I have an equipment that sends 140 16-bit words in sequence. I want to put the 140 numbers in a waveform using Streamdevice.
The manual says:
Separator = "";
String. Affects out and in commands.
When formatting or parsing array values in a format converter (see formats and waveform record), what string to write or to expect between values?
and gives this protocol example:
array_out {separator=", "; out "an array: (%.2f)";}
How can I address my case using something like the separator idea, when I don't have a separator, but a fixed byte size for each number?
Thank you for all help!
Streamdevice waveform - binary data stream with no separator Paduan Donadio, Marcio
Re: Streamdevice waveform - binary data stream with no separator Paduan Donadio, Marcio
Prev: RE: EDM questions Zelazny, Michael Stanley
Next: Re: string fanout or stringout after conditional check? Zimoch Dirk (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: Streamdevice waveform - binary data stream with no separator Paduan Donadio, Marcio
Next: Micronix MMC-10 Kevin Peterson
ANJ, 18 May 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
