1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: EDM questions
From: "Zelazny, Michael Stanley" <[email protected]>
To: lzf neu <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 18 May 2017 20:55:19 +0000
Select the widget with left-mouse-click then middle-mouse-click and use Group and Ungroup.
From: [email protected] [[email protected]] on behalf of lzf neu [[email protected]]
Sent: Thursday, May 18, 2017 06:55
To: [email protected]
Subject: EDM questions
hi,
I have two questions to consult you:
1) I want to control a object ( a circle for example) visible or invisible by two PVs. Let me assume PVa and PVb :
if PVa=1 and PVb=1 then the visibility of the circle is invisible otherwise is visible.
I open the circle properties window and have no idea how to process two PV names in Visibility PV blank.
2) how to control a text update widget visible or invisible according to PV.
however, there is no Visibility PV blank to fill in in Text update properties window.
Any help or any other methods will be appreciated and thanks in advance!
Zhefu
Re: EDM questions Southern, Tim
EDM questions lzf neu
Prev: Re: Streamdevice waveform - binary data stream with no separator Paduan Donadio, Marcio
Next: Re: Streamdevice waveform - binary data stream with no separator Zimoch Dirk (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: EDM questions lzf neu
Next: Re: EDM questions Southern, Tim
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
