1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Streamdevice waveform - binary data stream with no separator
Date: Thu, 18 May 2017 19:33:12 +0000
Thank you, Iain.
How do you let stream device know that you want exactly 140 numbers? Only setting NELM is sufficient?
Best regards,
Márcio Paduan Donadio
Software Engineer - TID-AIR-ACS - SLAC
De: Iain Marcuson <[email protected]>
Enviado: quinta-feira, 18 de maio de 2017 12:19
Para: Paduan Donadio, Marcio
Assunto: RE: Streamdevice waveform - binary data stream with no separator
I have used something similar.  You would use the %r format specifier, in I believe something like:
In “%2.2r”
You may need to add the “#” flag to account for endianness.  For this you would set the separator to be blank.
Iain.
From: [email protected] [mailto:[email protected]] On Behalf Of Paduan Donadio, Marcio
Sent: Thursday, May 18, 2017 1:25 PM
To: EPICS tech talk <[email protected]>
Subject: Streamdevice waveform - binary data stream with no separator
Good morning to all!
I have an equipment that sends 140 16-bit words in sequence. I want to put the 140 numbers in a waveform using Streamdevice.
The manual says:
Separator = "";
String. Affects out and in commands.
When formatting or parsing array values in a format converter (see formats and waveform record), what string to write or to expect between values?
and gives this protocol example:
array_out {separator=", "; out "an array: (%.2f)";}
How can I address my case using something like the separator idea, when I don't have a separator, but a fixed byte size for each number?
Thank you for all help!
Re: Streamdevice waveform - binary data stream with no separator Zimoch Dirk (PSI)
Streamdevice waveform - binary data stream with no separator Paduan Donadio, Marcio
Prev: Micronix MMC-10 Kevin Peterson
Next: RE: EDM questions Zelazny, Michael Stanley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Streamdevice waveform - binary data stream with no separator Paduan Donadio, Marcio
Next: Re: Streamdevice waveform - binary data stream with no separator Zimoch Dirk (PSI)
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
