1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: OPC UA EPICS device support license
To: EPICS Tech Talk <[email protected]>
Date: Tue, 16 May 2017 14:56:31 +0900
Hi Patrick,
On Sat, May 13, 2017 at 2:40 AM, Thomas, Patrick <[email protected]> wrote:
Am I correct in understanding that the use of the OPC UA EPICS device support available at https://github.com/bkuner/opcUaUnifiedAutomation requires the purchase of a license from Unified Automation?
Well ... depends on your definition of "use".
The client library by Unified Automation is licensed in a way that allows redistribution of applications as binaries (plus shared libraries) royalty-free. However, header files and documentation are explicitly under an NDA.
In other words: using an IOC with that support does not require a purchase, however, creating that IOC does require a license.
If I remember correctly, the upstream author Bernhard Kuner intends to make a statically linked IOC available.
If this is the case, is there OPC UA EPICS device support software available that does not require the purchase of a license?
Have a look at https://github.com/bkuner/freeOpcUaEpicsDevSup, which uses the free OPC UA client library available at https://github.com/FreeOpcUa/freeopcua. However, Bernhard did not find the free client stable and robust enough for production use, and switched to the commercially available client mentioned above.
Again: if someone with a license provides you with a binary, you can use it without restrictions.
Also: Unified Automation charges less than 4000 USD for a source code developer license on the Linux platform, which might be affordable in the end.
Cheers,
~Ralph
Re: OPC UA EPICS device support license Jack
OPC UA EPICS device support license Thomas, Patrick
Prev: Re: sending pickled python objects of epics channel access Kasemir, Kay
Next: Re: sending pickled python objects of epics channel access Wang Xiaoqiang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: OPC UA EPICS device support license Thomas, Patrick
Next: Re: OPC UA EPICS device support license Jack
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
