Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: sending pickled python objects of epics channel access
To: <tech-talk@aps.anl.gov>
Date: Mon, 15 May 2017 17:24:48 -0500
Hi Tim,
On 05/15/2017 05:00 PM, Madden, Timothy J. wrote:
> This is probably a bad idea... But if I were to take a python object,
> call pickle.dumps() to convert it into a string, I
> could then caput it to a waveform record. Then some other py client
> could caget, then call pickle.loads() from the
> waveform record. then we get the object back.  So we are sending python
> objects over epics CA.
> Has anyone tried this? Seems straightforward. Just how bad an idea is this?
I don't see it as a particularly terrible idea. I wonder if the DØ guys
at Fermilab ever used to do something like this (I do remember Fritz
Bartlett talking about pickling, but the tech-talk archives don't return
anything related).
The obvious limitation of pickling is that you are limiting other users
to writing their code in Python (or in some other language that has a
compatible de/serializing library — Perl's CPAN has such a module called
Python::Serialise::Pickle but it only had one release, in 2003), but
that might not be a problem for some projects. If you were to use a more
generic format such as JSON or YAML you might make life easier for
others, but if you're only expecting this data to ever pass between your
2 clients that shouldn't be a big issue.
- Andrew
Re: sending pickled python objects of epics channel access Kasemir, Kay
sending pickled python objects of epics channel access Madden, Timothy J.
Prev: Re: sending pickled python objects of epics channel access Matt Newville
Next: Re: sending pickled python objects of epics channel access Hartman, Steven M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: Re: sending pickled python objects of epics channel access Kasemir, Kay
ANJ, 15 May 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
